2 Replies Latest reply on Nov 28, 2010 12:13 PM by TheRealAgentK
    Stream Live Data, Is it possible?
    djkhalif Level 1
      Hi all,
      I am capturing data from a PLC via an OPC server and then storing that data in SQL. I would to present that data in real-time using CF. The changes between 1-5 seconds and runs for about 20 minutes then stops. Further down the line, I would need to go view a new batch as its produced and archive the old one. Has anyone accomplished this before? Also, I would like to see the data as it changes for a particular setting such as voltage readings. I've seen this with LabView but, I would like to move it to a browser. Thanks in advance!!! Happy Thanksgiving!!!!
      djkhalif
        • 1. Re: Stream Live Data, Is it possible?
          CutterBl Level 1
          You'll want to do a little research on using BlazeDS. Aaron West has some nice posts on his blog, and I think the are a few presentations on UGTV.
          • 2. Re: Stream Live Data, Is it possible?
            TheRealAgentK Level 2
            I agree with Cutter's suggestions.
            BlazeDS or Livecycle DS together with ColdFusion's Event Gateways will help you doing this and Aaron's blog/presentations are def. a good starting point. I talked about this topic just 2 weeks ago at cf.O(ANZ), DM me and I can ping you the presentation.
            Note one important difference between BDS and LCDS though - BDS does not do "real" streaming, it's basically HTTP polling with a frequency you can define. LCDS supports proper RTMP streaming/push (it's a commercial and not open source solution though) which scales _much_ better than HTTP polling. Both Flash/Flex clients as well as HTML-based clients are possible (via Flash/JS bridge) and there are ways to set up your architecture in a similar way to Comet-style longpolling.
            Cheers
            Kai
