5 Replies Latest reply on Nov 26, 2010 4:09 AM by Marijan Tompa [tomaxxi]
    how to Find Modified file
    Mac_06 Level 2
      In folder 3 -4 xml file are there I went to read only latest modified file
      I already find out time of all file but not get the latest file
      var myDocument = app.activeDocument;
      var myDocName = myDocument.name;
      var myFolder =myDocument.filePath;
      var Metafilepath=File(myFolder + "/");
          myPath = Metafilepath.getFiles("*.xml");
          if(File(myPath.exists))
            for(var i=0; i<myPath.length; i++)
             Temps = String(myPath[i]);
             Tempt1 = Temps.lastIndexOf("/");
             Tempt2 = Temps.substring(Tempt1+1);
             FileName = Tempt2.split(" ");
             var myNewFile = new File(Temps)
             var myModifiedFile = myNewFile.modified
                var myConcat = FileName + " "+ myModifiedFile
             var myNewFile1 = myConcat.toString();
             myPath[i].close();
      Thanks in advance
        • 1. Re: how to Find Modified file
          Marijan Tompa [tomaxxi] Level 4
          Hey!
          Here is working snippet:
          function findLastFile(fileXT /* file extension */, lastMod){
            var myFolder = myDocument.filePath;
            var myFiles = myFolder.getFiles("*."+ fileXT);
            if(myFiles.length != 0){
              myFiles.sort(function ( a, b )
                if ( a.created < b.created )
                  return -1;
                if ( a.created > b.created )
                  return 1;
                return 0;
              if(lastMod)myFiles.reverse();
              var myFile = myFiles[0];
              return myFile;
            }else{
              return false;
          And you can use it like this:
          // this will give you newest XML
          var myFile = findLastFile("xml", true);
          // this will give you oldest XML
          var myFile = findLastFile("xml", false);
          // also you can enter different extension
          // this will give you newest InDesign file
          var myFile = findLastFile("indd", true);
          Hope that helps.
          tomaxxi
          http://indisnip.wordpress.com/
          • 2. Re: how to Find Modified file
            Mac_06 Level 2
            Thanks for your quick reply Marijan Thompa
            but we are not getting the reference for lastMod
            So i am getting the error "lastMod" is not defined
            Could you eleborate it ?
            Many Thanks
            • 3. Re: how to Find Modified file
              Mac_06 Level 2
              Sorry......... for previous mail
              I think, I had asked out of track question
              your script did great work with some modification
                    if ( a.modified < b.modified )
                      return -1;
                    if ( a.modified > b.modified )
                      return 1;
                    return 0;
              //$.write(myFile)
                  return myFile;
                }else{
                  return false;
              Many Thaks for your great help.
              • 4. Re: how to Find Modified file
                Peter Kahrel Adobe Community Professional & MVP
                You can save yourself some typing:
                myFiles.sort(function ( a, b )  {return a.modified < b.modified});
                Peter
                • 5. Re: how to Find Modified file
                  Yes Peter, but I fond this in my old scripts and I used it for sorting by date
                  Thanks!
                  tomaxxi
