6 Replies Latest reply on Nov 30, 2010 4:03 AM by stefan zedlacher
    Problems with dataservice list update
    stefan zedlacher
      I'm using a PHP dataservice to manage different user data. Following the examples I created a search text field, a search button (get procedure) and a list (results). So far so good, everything is working. I created also a table from the datasource with the (automatic created) send button for the update. Also working, even the list updates immediately. Then I created a create procedure with another button. Works fine while not doing the get procedure. But when I select a item from the list (filled by the get procedure) and I decide to create a new item, i clear the list, clear the list.selectedIndex (=-1) but when I create the new item it appears in the list but the previous selected Item also changes (item.id and everything) so I have TWO identical items in the list! But if I do a reload, everything is as it should be (the new item is added, the old, previous selected on has its old name). So the PHP procs working as expected.
      I tried a lot with the procedures in flex, but nothing worked.
      What am I doing wrong? Is there a way to clear the token or the list/selected index?
      Any suggestions are welcome!
      g stefan
        • 1. Re: Problems with dataservice list update
          Aurelien Vannieuwenhuyze
          Hello,
          I don't know if my answer can help you...
          The result of the PHP request must be stored in an ArrayCollection.
          This ArrayCollection could be used as a dataProvider of your first list (Through Databinding).
          Create another ArrayCollection for the dataProvider of the other list.
          By the itemClick event of the first list, you can now
          - Clear the list
          - Add the element to the other list
          This is an example (Flex 3.5) :
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" minWidth="955" minHeight="600">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.ListEvent;
          //Result of your PHP request
          Bindable]
          public var listItemA:ArrayCollection = new ArrayCollection([{label:"ITEM 1",data:"1"},{label:"ITEM 2",data:"2"},{label:"ITEM 3",data:"3"}]);
          Bindable]
          public var listItemB:ArrayCollection = new ArrayCollection();
          public function copyItemToB(e:ListEvent):void
          //Clearing the list B
          listItemB.removeAll();
          //Adding the new Element;
          listItemB.addItem(e.currentTarget.selectedItem);
          </mx:Script>
          <mx:List x="26" y="21" dataProvider="{listItemA}" itemClick="copyItemToB(event)"></mx:List>
          <mx:List x="109" y="21" height="156" dataProvider="{listItemB}" width="76"></mx:List>
          </mx:Application>
          I Hope to have you helped
          • 2. Re: Problems with dataservice list update
            stefan zedlacher Level 1
            THX,
            I tried that but the problem is, that I use a spark.component.list and not an ArrayCollection. Changing the <s:List> to the <mx:List> ends at the point where I have to convert the valueObjects from the PHP dataservice to static Objects for the ArrayCollection. Nevertheless I tried it also with the <mx:List> attaching the values step by step - same result. I'll try with the ArrayCollection but I have a large amount of data so converting every valueObject to an ArrayCollection would be enormous.....
            lg stefan
            • 3. Re: Problems with dataservice list update
              Aurelien Vannieuwenhuyze Level 1
              hello,
              Can you send me a part of your code ?
              Thx.
              • 4. Re: Problems with dataservice list update
                here is the code and a link to a movie that shows you the problem.
                Also, here ist the URL to the online version where you could try (only change the dataset id to 3 or 2 or another number)
                Hope you find something...
                THX, stefan
                -- CODE --
                <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" creationComplete="creationComplete();"
                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="1000" minHeight="600"
                   xmlns:phplistuseruserservice="services.phplistuseruserservice.*"
                   xmlns:valueObjects="valueObjects.*"
                   xmlns:svreguliererausgeschiedenservice="services.svreguliererausgeschiedenservice.*" backgroundColor="#C7C7C7"
                   xmlns:sbpersonenparagraphservice="services.sbpersonenparagraphservice.*"
                   xmlns:skillsservice="services.skillsservice.*"
                   xmlns:skillsbewertungservice="services.skillsbewertungservice.*"
                   xmlns:campuskurseservice="services.campuskurseservice.*"
                   xmlns:versichererservice="services.versichererservice.*"
                   xmlns:bewerberservice1="services.bewerberservice1.*"
                   xmlns:skillspersonenservice="services.skillspersonenservice.*"
                   xmlns:campusteilnehmerexternservice="services.campusteilnehmerexternservice.*"
                   xmlns:campusanmeldungenservice="services.campusanmeldungenservice.*"
                   xmlns:net="flash.net.*" height="888"
                   xmlns:bemerkungenservice="services.bemerkungenservice.*"
                   xmlns:erinnerungenservice="services.erinnerungenservice.*"
                   xmlns:aktenvermerkeservice="services.aktenvermerkeservice.*"
                   xmlns:components="mh.components.*"
                   xmlns:zehnet="zehnet.flex.controls.*"
                   xmlns:dokumenteservice="services.dokumenteservice.*"
                   xmlns:besonderheitenservice="services.besonderheitenservice.*"
                   xmlns:bewerberservice="services.bewerberservice.*"
                   xmlns:benutzergruppenservice="services.benutzergruppenservice.*"
                   xmlns:svreguliererversichererservice="services.svreguliererversichererservice.*"
                   xmlns:example="com.example.programmingas3.fileio.*">
                <s:layout>
                <s:VerticalLayout horizontalAlign="center" paddingTop="10" gap="10"/>
                </s:layout>
                <fx:Style source="phpListPersonal.css"/>
                <fx:Script>
                <![CDATA[
                import flashx.textLayout.formats.Float;
                import mx.controls.Alert;
                import mx.controls.List;
                import mx.core.FlexGlobals;
                import mx.events.CalendarLayoutChangeEvent;
                import mx.events.FlexEvent;
                import mx.rpc.events.ResultEvent;
                import org.alivepdf.display.Display;
                import org.alivepdf.fonts.*;
                import org.alivepdf.layout.*;
                import org.alivepdf.pages.Page;
                import org.alivepdf.pdf.PDF;
                import org.alivepdf.saving.Method;
                import spark.events.IndexChangeEvent;
                import spark.events.TextOperationEvent;
                Ê
                // ---FUNKTIONEN--- //
                // nicht mit dem ersten sondern mit einem anderen Canvas im Viewstack starten
                private function creationComplete(): void {
                //Security.loadPolicyFile("http://www.example.com/typo3conf/ext/my_ext/pi1/static/crossdomain.xml");
                Security.allowDomain("*");
                Security.loadPolicyFile("http://intern.faircheck.at/crossdomain.xml");
                //Security.loadPolicyFile("http://localhost/faircheck/faircheck_personaldB-debug/crossdomain.xml");
                viewstack1.selectedIndex = viewstack1.getChildIndex(viewstack1.getChildByName("BemerkungenCanvas"));
                //ONLY FOR TESTING!!!!
                //viewstack1.selectedIndex = viewstack1.getChildIndex(viewstack1.getChildByName("fileUploadCanvas"));
                viewstack1.selectedIndex = viewstack1.getChildIndex(viewstack1.getChildByName("paragraphCanvas"));
                //Buttons active (enabled) schalten
                PersonParagraphBtn.enabled = true;
                skillsBewertungBtn.enabled = true;
                skillsBtn.enabled = true;
                BewerberBtn.enabled = true;
                campusKurseBtn.enabled = true;
                campusPersonenBtn.enabled = true;
                PersonNewsletterBtn.enabled = true;
                VersichererBtn.enabled = true;
                //Zeile Unten
                btnSaveImage.enabled = true;
                btnSaveErinnerung.enabled = true;
                btnSaveBemerkung.enabled = true;
                btnSaveAktenvermerk.enabled = true;
                btnSaveAusbildgunsausweis.enabled = true;
                btnSaveBesonderheiten.enabled = true;
                //focusManager.setFocus(username);
                //username.setFocus();
                //FlexGlobals.topLevelApplication.addEventListener(KeyboardEvent.KEY_UP, username.setFocus());
                if (ExternalInterface.available) {
                ExternalInterface.call('setFocus');
                } else {
                Alert.show("Browser not available");
                */ Ê Ê Ê Ê Ê Ê Ê
                //-----RELOAD SCRIPT-------------//
                private function reloadpage(event:MouseEvent):void
                var ref:URLRequest = new URLRequest("javascript:location.reload(true)");
                navigateToURL(ref, "_self");
                //login ausfŸhren !!
                //checkLogin(yes);
                private function reloadpagePersonen(event:MouseEvent):void {
                //-----FILE UPLOADER-----------//
                protected function dataGrid_creationCompleteHandler(event:FlexEvent):void
                getAllSB_Personen_paragraphResult.token = sBPersonenparagraphService.getAllSB_Personen_paragraph("","");
                protected function comboBoxFileUploaderPersonen_creationCompleteHandler(event:FlexEvent):void
                if(!sB_Personen_paragraph.personalID){
                protected function comboBoxBenutzergruppen_creationCompleteHandler(event:FlexEvent):void
                getColumnsSB_Personen_paragraphResult.token = sBPersonenparagraphService.getColumnsSB_Personen_paragraph();
                //getColumnsSB_Personen_paragraphResult.token = sBPersonenparagraphService.getColumnsSB_Personen_paragraph();
                //-----SCREENSHOT EXPORT-------//
                import mx.graphics.ImageSnapshot;
                import mx.graphics.codec.*;
                Ê
                private const jpegEnc:JPEGEncoder = new JPEGEncoder();
                private const xmlObj:XML = describeType(FileReference);
                /*Ê
                private function init():void {
                //textArea.text = xmlObj.toXMLString();
                public var call:int = 0;
                private function getDateForDokumente(dokGruppe:String, personenID:int):Date {
                //getAllDokumenteResult.token = dokumenteService.getAllDokumente(personenID);
                var datum:Date = new Date();
                var dokDate:Date;
                var count:int = 0;
                call++;
                //getAllDokumenteResult.lastResult[0].Rubrik
                for (var item:String in getAllDokumenteResult.lastResult){
                count+=1;
                if(getAllDokumenteResult.lastResult[item].Rubrik == dokGruppe){
                //if(Datum == dok
                dokDate = getAllDokumenteResult.lastResult[item].Datum;
                } else {
                //dokDate = datum;
                for (var documents in getAllErinnerungenByDatasetIDResult.lastResult){
                count+=1;
                if(documents.Rubrik == dokGruppe){
                //if(Datum == dok
                dokDate = documents.Datum;
                } else {
                //dokDate = datum;
                //dokDate = dokumente[0].Datum;
                //return (call.toString()+' - '+count.toString()+' '+personenID.toString());
                return dokDate;
                //return datum;
                //trace(dokDate);
                //-------------BEMERKUNGEN FUNKTIONEN-------//
                protected function btnSendBemerkungen_clickHandler(event:MouseEvent):void
                bemerkungen.personalID = personalIDTextInputBemerkungen.text;
                bemerkungen.Benutzer = benutzerTextInputBemerkungen.text;
                bemerkungen.zeitstempel = zeitstempelDateFieldBemerkungen.selectedDate;
                bemerkungen.Bemerkung = bemerkungTextInputBemerkungen.text;
                bemerkungen.idDatensatz = parseInt(idDatasetTextInputBemerkungen.text);
                bemerkungen.tableDatensatz = comboBoxDatasetTableBemerkungen.selectedItem.toString();
                if(bemerkungen.id==0){
                //CREATE Functions here
                createBemerkungenResult.token = bemerkungenService.createBemerkungen(bemerkungen);
                //Clear list
                getBemerkungenByDatasetIDResult.token = bemerkungenService.getBemerkungenByDatasetID("0","0");
                //reloadpage(event);
                } else {
                updateBemerkungenResult.token = bemerkungenService.updateBemerkungen(bemerkungen);
                //getBemerkungenByDatasetIDResult.token = bemerkungenService.getBemerkungenByDatasetID(idDatasetTextInput.text,tableDatasetTextInpu t.text);
                protected function btnDeleteBemerkungen_clickHandler(event:MouseEvent):void
                // DELETE Function here
                deleteBemerkungenResult.token = bemerkungenService.deleteBemerkungen(bemerkungen.id);
                protected function btnGetBemerkungenByDatasetID_clickHandler(event:MouseEvent):void
                getBemerkungenByDatasetIDResult.token = bemerkungenService.getBemerkungenByDatasetID(idDatasetTextInputBemerkungen.text,tableData setTextInputBemerkungen.text);
                protected function listBemerkungenDaten_changeHandler(event:IndexChangeEvent):void
                bemerkungen = listBemerkungenDaten.selectedItem;
                protected function listBemerkungenMX_changeHandler(event:ListEvent):void
                // TODO Automatisch generierter Methoden
                bemerkungen.Bemerkung = listBemerkungenMX.selectedItem.Bemerkung;
                [Bindable
                public var listItemB:ArrayCollection = new ArrayCollection();Ê
                protected function btnClearBemerkungen_clickHandler(event:MouseEvent):void
                listBemerkungenDaten.selectedIndex=-1;
                //listBemerkungenDaten.removeAll();
                //listItemB = listBemerkungenDaten;
                bemerkungen.id = 0;
                personalIDTextInputBemerkungen.text = txtUserPersonalID.text; //personalIDTextInputErinnerungen.text;
                benutzerTextInputBemerkungen.text = txtUserKuerzel.text; //benutzerTextInputErinnerungen.text;
                //Datum neu berechnen
                Ê//ÊÊÊÊdStart.selectedDate = new Date(new Date().getTime() - (5 * millisecondsPerDay));ÊÊ
                //ÊÊÊÊÊdEnd.selectedDate = new Date();
                zeitstempelDateFieldBemerkungen.selectedDate = new Date();
                bemerkungTextInputBemerkungen.text = "";;
                //personalIDTextInputBemerkungen.text = "";
                //benutzerTextInputBemerkungen.text = "";
                ///idDatasetTextInput.text = "";
                ///comboBoxDatasetTable.text = "SB_Personen_paragraph";
                ///getBemerkungenByDatasetIDResult.token = bemerkungenService.getBemerkungenByDatasetID(idDatasetTextInput.text,tableDatasetTextInpu t.text);
                ///createBemerkungenResult2.token = bemerkungenService.createBemerkungen(bemerkungen);
                protected function listSearchParagraphVersicherer_creationCompleteHandler(event:FlexEvent):void
                protected function btnPersonenDokumenteCanvas_clickHandler(event:MouseEvent):void
                // TODO Automatisch generierter Methoden-Stub
                protected function btnGetDokumente_clickHandler(event:MouseEvent):void
                getAllDokumenteResult.token = dokumenteService.getAllDokumente(sB_Personen_paragraph.id);
                protected function dataGridDokumentePersonen_creationCompleteHandler(event:FlexEvent):void
                public function insertDocument():void {
                //uploader.upload();
                //uploader.Filereference
                //mx..controls.Alert.show();
                //mx..controls.Alert.show('Jetzt geht es in die DATABASE!');
                </fx:Script>
                <!-- STATES -->
                <s:states>
                <s:State name="State1"/>
                <s:State name="register"/>
                </s:states>
                <!-- DECLARATIONS -->
                <fx:Declarations>
                <s:CallResponder id="getAllSV_Regulierer_ausgeschiedenResult"/>
                <svreguliererausgeschiedenservice:SVReguliererausgeschiedenService id="sVReguliererausgeschiedenService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <valueObjects:SB_Personen_paragraph id="sB_Personen_paragraph"/>
                <sbpersonenparagraphservice:SBPersonenparagraphService id="sBPersonenparagraphService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <s:CallResponder id="getAllSB_Personen_paragraphResult"/>
                <s:CallResponder id="updateSB_Personen_paragraphResult"/>
                <s:CallResponder id="getColumnsSB_Personen_paragraphResult"/>
                <s:CallResponder id="getAllSB_Personen_paragraphByKuerzelResult"/>
                <!-- bei den Versicherern-->
                <s:CallResponder id="getAllSB_Personen_paragraphByKuerzelResult3"/>
                <valueObjects:Bemerkungen id="bemerkungen"/>
                <bemerkungenservice:BemerkungenService id="bemerkungenService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <s:CallResponder id="getAllBemerkungenResult"/>
                <s:CallResponder id="getBemerkungenByDatasetIDResult"/>
                <s:CallResponder id="createBemerkungenResult"/>
                <valueObjects:Dokumente id="dokumente"/>
                <dokumenteservice:DokumenteService id="dokumenteService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <s:CallResponder id="createDokumenteResult"/>
                <s:CallResponder id="updateDokumenteResult"/>
                <s:CallResponder id="deleteDokumenteResult"/>
                <s:CallResponder id="getAllDokumenteResult"/>
                <valueObjects:Erinnerungen id="erinnerungen"/>
                <erinnerungenservice:ErinnerungenService id="erinnerungenService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <s:CallResponder id="createErinnerungenResult"/>
                <s:CallResponder id="deleteErinnerungenResult"/>
                <s:CallResponder id="getAllErinnerungenByDatasetIDResult"/>
                <s:CallResponder id="updateErinnerungenResult"/>
                <s:CallResponder id="createBemerkungenResult2"/>
                <s:CallResponder id="updateBemerkungenResult"/>
                <s:CallResponder id="deleteBemerkungenResult"/>
                </fx:Declarations>
                <mx:ViewStack id="viewstack1" width="1000" height="621" y="65">
                <!-- BEMERKUNGEN EINGABE DATEN -->
                <!--<s:NavigatorContent label="bemerkungenCanvas" width="100%" height="100%"></s:NavigatorContent> -->
                <mx:Canvas id="BemerkungenCanvas" label="Bemerkungen" backgroundColor="#E8E8E8">
                <s:Label text="Bemerkungen Eingabe Daten" fontSize="14" x="14" y="10"/>
                <mx:Form x="352" y="37" paddingLeft="5" paddingRight="5" paddingBottom="5" paddingTop="5" height="249" width="371" borderVisible="true" borderStyle="solid" borderColor="#9D9D9D">
                <mx:FormHeading label="Bemerkungen"/>
                <mx:FormItem label="Zeitstempel">
                <mx:DateField id="zeitstempelDateFieldBemerkungen" selectedDate="{bemerkungen.zeitstempel}"/>
                </mx:FormItem>
                <mx:FormItem label="Bemerkung" height="49" width="312">
                <s:TextArea id="bemerkungTextInputBemerkungen" verticalAlign="top" text="{bemerkungen.Bemerkung}" width="205" height="49"/>
                </mx:FormItem>
                <mx:FormItem label="Tabelle" width="290">
                <!--<mx:ComboBox x="775" y="523" id="comboboxUserGruppe" dataProvider="{ [ 'Regulierer', 'Intern', 'Key Account', 'Kooperationspartner','Franchisenehmer','Bewerber Ausgeschiedene','Externe (Campus)','Superuser','Administrator' ] }" textAlign="right" width="179"/>-->
                <mx:ComboBox id="comboBoxDatasetTableBemerkungen" dataProvider="{ [ 'SB_Personen_paragraph', 'Skills', 'Bewertungen', 'Bewerber', 'Campus Kurse', 'Campus Personen', 'Newsletter', 'Versicherer' ] }" />
                </mx:FormItem>
                <mx:FormItem label="PersonalID" width="307">
                <s:TextInput id="personalIDTextInputBemerkungen" text="{bemerkungen.personalID}" width="207"  selectable="true" editable="false" contentBackgroundColor="#E0DCDC"/>
                </mx:FormItem>
                <mx:FormItem label="KŸrzel" width="316">
                <s:TextInput id="benutzerTextInputBemerkungen" text="{bemerkungen.Benutzer}" width="207"  selectable="true" editable="false" contentBackgroundColor="#E0DCDC"/>
                </mx:FormItem>
                <s:HGroup width="354" height="40" paddingLeft="0" paddingRight="0" paddingTop="10" paddingBottom="10" gap="5">
                <s:Button id="btnDeleteBemerkungen" label="Lšschen"  click="btnDeleteBemerkungen_clickHandler(event)"/>
                <s:Button id="btnCreateBemerkungen" label="Create"  click="btnCreateBemerkungen_clickHandler(event)" enabled="false"/>
                <s:Button id="btnSendBemerkungen" label="speichern (send)" click="btnSendBemerkungen_clickHandler(event)"/>
                <s:Button label="neu (clear)" id="btnClearBemerkungen" click="btnClearBemerkungen_clickHandler(event)"/>
                </s:HGroup>
                </mx:Form>
                <mx:Form x="6" y="37" height="249" width="340" paddingLeft="5" paddingRight="5" paddingBottom="5" paddingTop="5" borderVisible="true" borderStyle="solid" borderColor="#9D9D9D">
                <mx:FormItem label="TableDataset"  width="222">
                <s:TextInput id="tableDatasetTextInputBemerkungen" text="SB_Personen_paragraph"/>
                </mx:FormItem>
                <mx:FormItem label="IdDataset" width="222">
                <s:TextInput id="idDatasetTextInputBemerkungen" text="{sB_Personen_paragraph.id.toString()}"/>
                </mx:FormItem>
                <s:Button label="Bemerkungen Abfragen" id="btnGetBemerkungenByDatasetID" click="btnGetBemerkungenByDatasetID_clickHandler(event)"/>
                <s:List width="270" id="listBemerkungenDaten" labelField="Bemerkung" change="listBemerkungenDaten_changeHandler(event)">
                <s:AsyncListView list="{getBemerkungenByDatasetIDResult.lastResult}" />
                </s:List>
                </mx:Form>
                <s:TextArea x="731" y="57" text="{listBemerkungenDaten.selectedItem.id}" height="131" enabled="false"/>
                <s:TextArea x="733" y="226" text="{bemerkungen.id}" height="60" enabled="false"/>
                <s:Label x="731" y="37" text="selectedItem Liste" color="#999999"/>
                <s:Label x="731" y="205" text="Objekt Bemerkungen id" color="#999999"/>
                <mx:List x="14" y="294" width="267" id="listBemerkungenMX" dataProvider="{getBemerkungenByDatasetIDResult.lastResult}" labelField="Bemerkung" change="listBemerkungenMX_changeHandler(event)" enabled="false"></mx:List>
                <s:HGroup width="1000" height="30" textAlign="right" x="-2" y="476">
                <s:Label text="angemeldet als: " verticalAlign="bottom" paddingLeft="0" paddingTop="5"/>
                <s:TextInput id="txtUserLogOn" textAlign="left" paddingTop="5" contentBackgroundAlpha="0.0" borderVisible="false" color="#FFFFFF" width="280"/>
                <s:TextInput id="txtUserKuerzel" textAlign="right" paddingTop="5" contentBackgroundAlpha="0.0" borderVisible="false" color="#FFFFFF" width="574" text="Gast"/>
                <s:TextInput id="txtUserPersonalID" paddingTop="5" contentBackgroundAlpha="0.0" borderVisible="false" color="#FFFFFF" width="43" text="0000" textAlign="left"/>
                </s:HGroup>
                </mx:Canvas>
                </mx:ViewStack>
                </s:Application>
                • 5. Re: Problems with dataservice list update
                  Hello,
                  When i test your application on IE with Flash Debugger Active X (you can download it for Mac at this adress : http://www.adobe.com/support/flashplayer/downloads.html), i have this error when i use the clear button :
                  Error: Attempting to update a UID property 'id' which is not supported.
                  at mx.data::DataMessageCache/logUpdate()
                  at mx.data::DataStore/http://www.adobe.com/2006/flex/mx/internal::logUpdate()
                  at mx.data::ConcreteDataService/itemUpdateHandler()
                  at flash.events::EventDispatcher/dispatchEventFunction()
                  at flash.events::EventDispatcher/dispatchEvent()
                  at mx.data.utils::Managed$/setProperty()
                  at valueObjects::_Super_Bemerkungen/set id()
                  at BemerkungenStandalone/btnClearBemerkungen_clickHandler()
                  at BemerkungenStandalone/__btnClearBemerkungen_click()
                  And all the ID have the 0 value.
                  I'm looking for a solution
                  Regards
                  Aurélien
                  Date: Tue, 30 Nov 2010 03:18:34 -0700
                  To: aurelien.vannieuwenhuyze@hotmail.fr
                  Subject: Problems with dataservice list update
                  Hi,here is the code and a link to a movie that shows you the problem.
                  http://stefan.zedlacher.net/adobe/listProblems.html
                  http://intern.faircheck.at/db/personen/BemerkungenStandalone.html
                  THX, stefan
                  -- CODE --
                  <s:layout>
                  </s:layout>
                  <fx:Script>
                  <![CDATA[
                  Ê
                  // -FUNKTIONEN- //
                  //viewstack1.selectedIndex = viewstack1.getChildIndex(viewstack1.getChildByName("fileUploadCanvas" ));
                  viewstack1.selectedIndex = viewstack1.getChildIndex(viewstack1.getChildByName("paragraphCanvas") );
                  //Zeile Unten
                  //FlexGlobals.topLevelApplication.addEventListener(KeyboardEvent.KEY_U P, username.setFocus());
                  } else {
                  */ Ê Ê Ê Ê Ê Ê Ê
                  • 6. Re: Problems with dataservice list update
                    yes, I got the same error some times. I think it has to do with some database entries but I'm not sure. In the code, the "reset" of the id (bemerkungen.id = 0) is only a workaround to clear the selected id. You could see both ids in the two textfields on the right.
                    Thx, stefan
