5 Replies Latest reply on May 12, 2011 7:20 AM by PhantomGAD
    spark Form
    pzzzza
      is it possible to control vertical gap between <s:Form> children?
      default gap between <s:FormItem> seems large for me
      im using
      <s:Scroller width="100%" height="100%">
           <s:Group>
                <s:Form>
                     <s:FormItem label="asd:">
                          <s:Label id="interanalID"/>
                     </s:FormItem>
                     <s:FormItem label="isVerified:">
                          <s:CheckBox id="isVerified"/>
                     </s:FormItem>
                     <s:FormItem label="Name:">
                          <s:TextInput id="instrumentName"/>
                     </s:FormItem>
                 </s:Form>
           </s:Group>
      </s:Scroller>
        • 1. Re: spark Form
          Shongrunden Adobe Employee
          You could change the gap on the Form's layout:
                                 xmlns:s="library://ns.adobe.com/flex/spark">
              <s:controlBarContent>
                  <s:HSlider id="hs" minimum="-10" maximum="50" value="6" />
              </s:controlBarContent>
              <s:Form>
                 <s:layout>
                      <s:FormLayout gap="{hs.value}" />
                  </s:layout>
                  </s:FormItem>
                  </s:FormItem>
                  </s:FormItem>
              </s:Form>
          </s:Application>
          • 2. Re: spark Form
            Aurelien Vannieuwenhuyze
            I think that you must use the <mx:Form> component.
            Because there is no implementation of <s:Form> in the Spark library :
            <s:Scroller
            <s:Group>
            <mx:Form verticalGap="30" x.stModConnexion_Start="57" y.stModConnexion_Start="33">
            <mx:FormItem label="asd:">
            </mx:FormItem>
            <mx:FormItem label="isVerified:">
            </mx:FormItem>
            <mx:FormItem label="Name:">
            </mx:FormItem>
            </mx:Form>
            </s:Group>
            </s:Scroller>
            • 3. Re: spark FormItems
              eprevot123
              Even reducing the gap to 0, the spark FormItems are still too tall. I would like to have the same space between my components than I had with mx Form/FormItems.
              how can we reduce the padding of FormItems ?
              • 4. Re: spark FormItems
                CleanCoder
                You will need to create a custom FormItem skin. The current FormItemSkin class uses a constraint based layout with fixed values to control the layout. Make a copy of the class and customize as required.
                • 5. Re: spark FormItems
                  PhantomGAD
                  you can set negative values
                  <s:layout>
                          <s:FormLayout gap="-10" paddingLeft="-15" paddingRight="-15"/>
                  </s:layout>
