6 Replies Latest reply on Jul 17, 2007 9:30 PM by Ambili
    Flex with Java - DB data access
    Ambili
      Hello, folks,
      I am developing a Java application and realized that I need some advice. My application is simple:
      I have a MSSQL server, tomcat 5.5 ,flex data services.
      In my application , i have two combo boxes.. country, town..
      i have populated the country combobox with the values from DB(country table) obtained using the fill(List ListArgs) in Assembler Class.
      Now, based on the country selected in have to populate my town combobox from (town table)
      How can i populate the town combobox from the DB based on the country code?
      Is there any function to pass the selected index and populate the town combo box..????
      My code is as below:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" >
      <mx:DataService id="ds" destination="quick-search-country" autoCommit="false" autoSyncEnabled="false"/>
      <mx:DataService id="tds" destination="quick-search-town" autoCommit="false" autoSyncEnabled="false"/>
      <mx:ArrayCollection id="cntry_list"/>
      <mx:ArrayCollection id="town_list"/>
      mx:Panel layout="absolute" backgroundColor="#c6daf5" verticalCenter="0" horizontalCenter="0">
      <mx:Form id="SearchForm">
      <mx:TabNavigator >
      <mx:Canvas label="Hotel" width="339" height="234" backgroundColor="#ffffff">
      <mx:Label x="10" y="91" text="Country :" alpha="0.12" />
      <mx:ComboBox x="93" y="89" fontSize="10" id="Country" dataProvider="{cntry_list}"
      labelField="countryName" creationComplete="ds.fill(cntry_list)"
      change="tds.getItem(Country.selectedItem)" prompt="United Kingdom" >
      </mx:ComboBox>
      <mx:Label x="10" y="126" text="Town / City :" fontFamily="Georgia" alpha="0.12"/>
      <mx:ComboBox id="town" x="94" y="124" fontSize="10" dataProvider="{town_list}"
      labelField="townName" prompt="London WC1" >
      </mx:ComboBox>
      </mx:Canvas>
      </mx:TabNavigator>
      </mx:Form>
      </mx:Panel>
      </mx:Application>
      this is my main.mxml . I have CountryAssembler to fill the country combo and a DAO class . Have a Town assembler..
      Please advice me on how to populate the town combo based on country selected from the DB...
      I am really stuck up... and also dont have any documentation on Flex data services with Java support..
      please give me some suggestions on this.
      Thanks in Advance,
      Ambili
        • 1. Re: Flex with Java - DB data access
          Mete Atamel
          Hi Ambili,
          First, assuming that you're using LCDS 2.5 (new name for FDS after 2.0), here's the developer's guide that has a lot of information: http://www.adobe.com/go/lcds_devguide
          Second, I think what you're trying to achieve can be done with a custom DataService.fill method. DataService.fill can take in optional arguments that can be processed in your Assembler class.
          On the client side, assuming that you have an ArrayCollection named towns where you keep track of towns, and a String of countryName where you keep track of the current name of the country being displayed, when a user selects a country, you can call tds.fill(towns, 'by-country', countryName).
          On the server side, in your TownAssembler, you will need to handle the parameterized fill and do something like this in the fill method:
          public Collection fill(List fillParameters)
          if (fillParameters.size() == 0)
          return dao.getTowns(); // This will return all the towns probably.
          String queryName = (String)fillParameters.get(0);
          if (queryName.equals("by-country"))
          return dao.getTownsByCountry(((Integer)fillParameters.get(1)).intValue());
          Of course, I'm assuming here that you have a TownDAO that performs the DB operations to actually retrieve the list of towns and return it back.
          • 2. Re: Flex with Java - DB data access
            Ambili Level 1
            Hi Mete,
            Thanks for ur reply , Mete. Your reply helped me a lot. Am using FDS 2.0.
            I have a doubt in combo box area itself.
            I have two tables by name country_list and town_list
            country_list consists of identity column , country_name and country_code
            town_list has identity column, country_code, town_code and town_name
            Normally while we use combobox in jsp, we have key value pairs for combo box..
            For eg:- if we have a Country combo , we have the country name(United States) as text displayed and its country code (US) as key.
            So if i select the United States , i will be returned with the value 'US' so that i can use it in query directly as
            Select town_name, town_code from town_list where country_code ='US'
            But while using flex , am not able to retieve the country_code from country combo. its only returning the text and the id.
            Here am forced to write a nested query as follows
            Select town_name, town_code from town_list where country_code =( Select country_code from country_list where country_name='United States')
            Is there any way to get the country_code as key while i select the country from country combo .
            And also how to keep 'United States' as selected during the intial load of the page.
            prompt="Select Country" />
            Thanks in Advance,
            Ambili
            • 3. Re: Flex with Java - DB data access
              Mete Atamel Level 1
              Hi Ambili, as long as your cntry_list array contains Country objects, the ComboBox's selectedItem property should have the currently selected Country with all of its properties.
              Are you using lazy loading by any chance in your DataService?
              • 4. Re: Flex with Java - DB data access
                Ambili Level 1
                hi Mete,
                Combo box's selecteditem property is not returning country_code..
                My country list contains country objects... Country Code and Country name.
                is this problem occurs bcoz am not mapping country_code any where in mxml ,
                Should i map it some where like CountryName?
                hw i will retrieve the data?
                What is lazy loading.. dint understand that?
                thx,
                Ambili
                • 5. Re: Flex with Java - DB data access
                  Level 7
                  Ambili,
                  Mete is suggesting that since Country.selectedItem is your Country object,
                  the country_code should be accessible via Country.selectedItem.country_code
                  (although I'm personally not much of a fan of direct binding syntax, one
                  thing I saw in your posts was that you have different conventions for how
                  you name these properties, sometimes you refer to them in the style country_name
                  and then others as countryName... so depending on how you've actually implemented
                  it, it may be Country.selectedItem.countryCode or Country.selectedItem.country_code).
                  Pete
                  • 6. Re: Flex with Java - DB data access
                    Ambili Level 1
                    hi Pete,
                    Good morning... thank you for your reply..
                    Actually i dint go thru any documentation for flex.. just looked at the sample application and started coding..
                    The convension i use in coding is countryName and countryCode.
                    In the post i dint take care of convension. sorry for that.
                    Thanks for the reply. It really helped me a lot..
                    Thx,
                    Ambili
