3 Replies Latest reply on Dec 4, 2011 10:23 AM by originaltomato
    As3maillib examples?
    DachFlach Level 1
      I am looking to have a go at implementing email into AIR.
      Are there any as3maillib examples out there?
      I have the classes but have found no implementation examples.
        • 1. Re: As3maillib examples?
          You know...i'm trying to use it also and it just doesn't work.
          I always get :"530 5.7.0 Must issue a STARTTLS command first. h43sm3407682wes.11".
          I think this library is no good. I'm looking for another one.
          • 2. Re: As3maillib examples?
            I've never used as3maillib, but I access IMAP accounts via TLS using the as3crypto library that has classes to support TLS. Note however that the current TLS socket version of as3crypto does not work under iOS. I made it work under iOS, but it still needs alot of testing...
            Not knowing as3maillib, I bet in combination with as3crypto it may give you a good start to develop email client functionality.
            Best regards
            • 3. Re: As3maillib examples?
              You are the only one who has  a solution for using as3crypto on the whole web, please help, what do I have to change?
              I need it for sending smtp via airxmail ..
              best regards,
