1 Reply Latest reply on Nov 29, 2010 12:24 PM by Steve L Walker
    Variable type
    HyungSikKIM Level 1
      Dear All
      I tried to set a path of field as below Code.
      in case of case1, i can set a presence property to extPath.
      but in case of case2, i can't set a presence property to extPath.
      is there any function to change type of variable such as toString().
      case 1
           var extPath = Test_Report.Test_Result2;
      case 2
           var extPath = "Test_Report.Test_Result2";
      ------------------------------------------ Code ------------------------------------------
      var typeOfdevice = Test_Report.Test_Cover.sub_Cover_info.Cover_info.info_Device.D_Drop.rawValue;
      var changeEvent = xfa.event.change;
           if(typeOfdevice == "범용"){
                Init.setPresence(extPath, "visible");
      // In the Init variable group
      //Set Presence of Field or subform
      function setPresence(obj, block){
      obj.presence = block;
        • 1. Re: Variable type
          Steve L Walker Level 5
          var extPath = Test_Report.Test_Result2.rawValue;
          If est_Report.Test_Result2 is a text field extPath should be a string. If you are suspicious of type coercion and run-time errors you can use standard JavaScript methods, for example
          var str = Test_Report.Test_Result2.rawValue;
          var extPath = str.toString();
          or
          var extPath = parseInt(str);
          or
          var extPath = parseFloat(str);
          etcetera.
          Steve
