2 Replies Latest reply on Jul 12, 2007 8:16 PM by hylim
    Passing data between datagridcolumn
    hylim
      I have the following data:
      class Item
      public var name:String;
      public var infos: ArrayCollection;
      class Info
      public var id:String;
      var items: ArrayCollection; //where items are arrays of Item
      I am creating a datagrid as follows:
      <mx:DataGrid id="dg" dataProvider="{items}" >
      <mx:columns>
      <DataGridColumn dataField="name" headerText="Name" />
      <DataGridColumn dataField="infos" headerText="Status" itemRenderer="{myRenderer}" />
      </mx:columns>
      </mx:DataGrid>
      in myRenderer.mxml:
      I need to access the name data from Item... but my dataField is {infos}
      In this case, how can I pass data from 1 column to another?
      Thank you very much.
      Regards,
      hy
        • 1. Re: Passing data between datagridcolumn
          ntsiii Level 3
          You do not need to set dataField for a colunmn with an item renderer. You will get a reference to the entire item object in the set data() function.
          Tracy
          • 2. Re: Passing data between datagridcolumn
            hylim Level 1
            Hi Tracy,
            Thank you for your reply.
            Just to confirm,
            in the function set data(value:Object) - this means I will get the reference to the Item class.
            I would like to ask for a more complicated case:
            Now my class is:
            class Item
            class Info
            public var ids:ArrayCollection;
            var infos: ArrayCollection; //where infos are arrays of Info
            I have create a custom DataGridColumn component:
            class myDataGridColumn extends DataGridColumn
            public var dataProvider: ArrayCollection;
            In my datagrid, I dynamically add myDataGridColumn:
            <mx:DataGrid id="dg">
            <mx:columns>
            <myDataGridColumn dataProvider={items} headerText="Name" />
            <myDataGridColumn dataProvider={infos} headerText="Status" itemRenderer="{myRenderer}" />
            </mx:columns>
            </mx:DataGrid>
            in myRenderer.mxml:
            For each row, I need to access the name data from items; where the renderer will use the name to search through ids, before displaying the result.
            In this case, how can I pass data from 1 column to another, since the dataProvider for each column is different?
            Once again, thank you very much.
            Regards,
            hy
