6 Replies Latest reply on Nov 30, 2010 7:11 AM by TheGarfunkal
    Can't change dataprovider of a Pie Chart
    TheGarfunkal
      Hiya
      I'm sure I'm being a bit dense, but I don't seem to be able to update a dataprovider for a pie chart.  The plan is to filter the results..... but one thing at a time!
      Anyway
      I have two arraycollections:  RagPie and RagPieDrill (its not really a drill - ignore the terminology) I debugged to check and both have data in when the page loads.
      All I am trying to do is switch the data in the chart.  The second AC is created when the page loads and does have data.
      Below is my mxml;
      <mx:PieChart  id="pcBuildSummary"
      creationComplete="{PodContentBase.RagPie()}"
      dataProvider = "{PodContentBase._RagPie}"
      itemClick="imhittingit(event)">
      <mx:series>
      <mx:PieSeries id = "pcBuild"
              field="Volume"
               nameField="RAG"
               explodeRadius="0.05"
               fillFunction="PieFilling">
      </mx:PieSeries>
      </mx:series>
      </mx:PieChart>
      And the AS that is meant to be updating: (its in a hitData to allow me to filter the second AC later)
      private function imhittingit(e:ChartItemEvent):void {
      pcBuildTeamBuildSummary.dataProvider = PodContentBase._RagPieDrill;
      pcBuild = new PieSeries;
      pcBuild.field = "Volume";
      pcBuild.nameField = "Breached";
      //pcBuildTeamBuildSummary.validateNow();
      trace("field " + pcBuild.field)
      trace("name " + pcBuild.nameField)
      Can anyone help?  Much thanks
      Andrew
        • 1. Re: Can't change dataprovider of a Pie Chart
          Aurelien Vannieuwenhuyze Level 1
          Hello,
          Can you post your code of the PodContentBase.RagPie() method ?
          thanks
          Regards
          • 2. Re: Can't change dataprovider of a Pie Chart
            MartinHviid
            Hi Andrew
            I have looked a bit at you example, but I can't really understand it.
            There are some objects you got to explain a bit more if I have to help.
            Like:
            PodContentBase
            pcBuildTeamBuildSummary Vs. pcBuildSummary
            Cheers
            Martin
            • 3. Re: Can't change dataprovider of a Pie Chart
              Hello,
              Can you post the code of the PodContentBase.RagPie() ?
              Regards.
              • 4. Re: Can't change dataprovider of a Pie Chart
                TheGarfunkal Level 1
                Martin!
                Ugly scenes here - you are right to want to look at
                pcBuildSummaryBuildSumary v pcBuildSummary
                pcBuildSummaryBuildSumary is incorrect - i've been trying to update an incorrect/non exisitant Piechart.. for hours.
                i feel 100% stupid - sorry for wasting everyones time - although i fully expect to fail on filtering the AC.
                thanks guys
                • 5. Re: Can't change dataprovider of a Pie Chart
                  MartinHviid Level 2
                  Np, also seemed a bit strange, some times looking at code to much makes you blind.
                  Please rate answer
                  Cheers
                  Martin
                  • 6. Re: Can't change dataprovider of a Pie Chart
                    it looks all good now  - Last issue... (pushing luck)
                    When it changes dataprovider, it doesnt alter the nameField label - it labels it 'Null'  - its fine for the other AC - even when it switches back.
                    I 'think' I have the nameField right, but that fact that the numeric in both AC's are the same makes me feel that its an accdient that the second  dataprovider works at all -
                    Debugger for second AC
                    AS.
                           var RAG:String  = e.hitData.item.RAG;
                            if (RAG == "Green"){
                         PodContentBase._RagPieData = "G"}
                         else if (RAG== "Red"){
                         PodContentBase._RagPieData = "R"}
                         else if (RAG== "Amber"){
                         PodContentBase._RagPieData = "A"}
                         else {
                         PodContentBase._RagPieData = "ChangeDP"};
                    if (PodContentBase._RagPieData == "ChangeDP"){
                    pcBuildSummary.dataProvider = PodContentBase._RagPie;
                    pcBuild.nameField = "RAG";
                    PodContentBase._RagPieDrill.refresh();
                    else {
                    pcBuildSummary.dataProvider = PodContentBase._RagPieDrill;
                    PodContentBase._RagPieDrill.filterFunction = filterFunc;
                    MXML
                    <mx:series>
                            field="Volume"
                             nameField="RAG"
                    </mx:PieSeries>
                    </mx:series>
                    </mx:PieChart>
                    the two queries to pull data back (just the main function - not the full code - It doesnt bring back the data)
                    public static function RagPie():void {
                    mssqlQuery("SELECT CASE SLARag WHEN 'R' THEN 'Red' WHEN 'A' THEN 'Amber' WHEN 'G' THEN 'Green' WHEN 'RR' THEN 'Dark Red'  END as  RAG , COUNT (Slarag)  as  Volume FROM [CMI_ClientMI].[Portal].[BatchUpdate] WHERE ID in ( SELECT MAX([Id]) [Application] FROM  [CMI_ClientMI].[Portal].[BatchUpdate] group by Application )  group by SLARag ORDER BY  CASE SLARag  WHEN 'RR' THEN 1 WHEN 'R' THEN 2 WHEN 'A' THEN 3 WHEN 'G' THEN 4 END ", "RagPie");
                    public static function RagPieDrill():void {
                        mssqlQuery("SELECT Breached, SLARag,  Sum(Volume) as Volume FROM [CMI_ClientMI].[Portal].[vwRagBreach] GROUP BY  Breached, Sort, SLARag ORDER BY Sort","RagPieDrill");
