3 Replies Latest reply on Sep 19, 2011 5:10 AM by hussam ihmaidi
    Far Dependency
    YaserMM
      Hello all,
      I am getting an error that popped up when I made an undeploy and then tried to deploy again and what I do I could neither get rid of the error not deploy my process.
      The error message says something like, "Far Dependency: name of the process is not defined in the descriptor"
      I have tried every possible thing ( including deleting the problematic sub process itself ) but no luck
      Does anyone have an idea how to overcome this, any similar experience?
      My installation is LiveCycle ES2, patch 1, on Windows7. Workbench 9.5
      Thank you,
        • 1. Re: Far Dependency
          stormshark Level 1
          Hi Budy I got the same problem but I figure out something which is to do something with C:\Documents and Settings\yusufgoy\Workbench ES2\test_Bilgin\1.0 PoC.process_dependency file . I opened it with notepad but I couldnt save same format as before. ı m still working on it . PLEASE SOME EXPERT HELP US
          • 2. Re: Far Dependency
            YaserMM Level 1
            Hello,
            In one of my trials I installed SP2 and problem disappeared, I looked into the release notes of the service pack and found some talk about sub-processes references problem when copying a sub-process around or upgrading to new version.
            Greetings,
            Yasser
            • 3. Re: Far Dependency
              hussam ihmaidi
              Thank you Yaser, Abu Amr,
              I forgot to install SP2 and I faced this error in my new installation and deployment, but after installing the patch... now it's OK
              Regards
              Hussam
