3 Replies Latest reply on Dec 17, 2010 7:37 AM by The Flex Viking
    RemoteObject InvokeEvent how to preventDefault
    Angel Ivanov Level 1
      I am trying to register InvokeEvent listener on every RemoteObject and to stop remote call if some logic requires it. Is it possible? Until now I have not success! Thank you!
        • 1. Re: RemoteObject InvokeEvent how to preventDefault
          OK. I found that Operation class has method cancel(), but after invoke it the call still happen! Please help!
          • 2. Re: RemoteObject InvokeEvent how to preventDefault
            Xung Level 1
            Hi Angel Ivanov,
            Maybe you must create a customized class, such as
            public class InvokeEventCustom extends InvokeEvent{
                 public function InvokeEventCustom(type:String, cancelable:Boolean,...){
                      super(...);
            And you must specify parameter: cancelable into true.
            And you create a customized class, such as
            public class RemoteObjectCustom extends RemoteObject{
                 //Codes
                 //Events (InvokeEventCustom)
            And use the RemoteObjectCustom instead of RemoteObject
            Please try, I think it's OK. But I'm not use and test
            Andy
            • 3. Re: RemoteObject InvokeEvent how to preventDefault
              The Flex Viking Level 1
              A couple thoughts.
              I have a similar use case in which a user keys in search information.  If they stop keying in for 1 second, the system invokes a RemoteObject query operation on the backend.  If they key in more information before the results were returned, I want to cancel any pending operations and start a new one.  Otherwise, screwy things might happen with updating the UI with a result set that is really no longer valid.
              Now, this is only a query, so it's not updating the back-end.  So, I can do something like RemoteObject.operations["invoke"].cancel();
              If you were actually updating the backend and wanted to cancel.  Well, I don't think there is anyway to HALT an operation at the RemoteObject destination once it's been passed to it.  I think you would have to build that sort of functionality into your communication with your destination.
