1. Re: Rotate at opening?
JJMack Dec 1, 2010 1:06 PM (in response to phosphorspitter)phosphorspitter wrote:
Need a script that rotates a jpg CCW when each jpg is opened in PSCS.
It easy to rotate every image ccw you can do that with an action or a script and have Photoshop execute the action or script for the open event using the event manager. I do no believe this is what you need. You only want rotate Portrait image CCW or CW for the two possible landscape positions thery are currently in. A script would need to be find out the actual image's orientation. If the camera is not recording the orientation properly I don't think that is possible. If the camera was recording the orientation correctly you would not need anything. To rotate an image to the proper orientation you would need a program to annalize the image contents looking for objects like buildings faces trees to be able to do the proper rotate if needed.
2. Re: Rotate at opening?
phosphorspitter Dec 1, 2010 1:38 PM (in response to JJMack)The event Manager invoking the action does the job.
Thanks for the help.
