0 Replies Latest reply on Dec 1, 2010 9:04 PM by blue13sky
    Unable to deploy flex application on server
    blue13sky
      Hello there,
      After a lot of researches and copy/paste on Google, I finally decide to create a topic here, that means I am totally desperate.
      I have a dev environment on a Windows platform with  Apache/PHP/MySQL and Flash Builder 4. I am using the Zend Framework in  order to communicate with PHP classes in Action Script. Locally, all  work perfectly, PHP works and content is correctly updated in my Flex  apps.
      But I have a problem when i deploy application on my server(linux).
      I just export my Flex app to a release build, I modify the amf_config.ini. And I am sure my configuration is correct.
      ZendFramework is correctly installed.
      Class "xxxxxx" does not exist: Plugin by name 'xxxxxx' was not found in the registry; used paths: : /xxxxxx/www/services/
      The path is correct, my services are in the  "services" folder, but Zend does not find the classes. Is there a  difference between Zend Framework running on Windows and deployment  server.
      Can you help me?
      Thanks a lot.
      Regards.
      Akash
