2 Replies Latest reply on Jul 18, 2007 9:38 AM by noviceone
    Displaying a list
      I need to post a list of names with addresses. I have the list in an Excel file but I could easily convert that to anything.
      I want to display about 50 lines, with a scroll bar for the rest. This is kicking my butt. I would think it should be pretty easy but....
        • 1. Re: Displaying a list
          Rothrock Level 5
          Your question is a bit vague and open ended. Have you tried anything? Or are you stuck at the very beginning?
          Personally I would convert the list to XML, load it in. And then depending upon various things I would display it. One long 300 name list is a lot to scroll through. So I might want it to have like A-M, N-Z or something.
          You could also use CSS to format it for readability.
          Take the different parts one at a time, because each step is really independent of the others. So if you don't want to start with loading XML, perhaps start with displaying lines of text with a scroller. Later you can pass it whatever text you want after you know how.
          Break it down, divide and conquer.
          • 2. Re: Displaying a list
            noviceone Level 1
            thanks Rothrock
            I have converted the list to XML. Is there example code of how to display it with a scroller?
