1. Re: Can't play published projects(*.htm) from Captivate 5
RodWard Dec 2, 2010 9:22 AM (in response to svenja-1)This is a long shot, but:
Have you tried clearing out the Captivate cache?
Edit > Preferences > Global > General Settings > Clear Cache button.
I've noticed some really weird Cp5 issues when the cache gets to a certain size.
2. Re: Can't play published projects(*.htm) from Captivate 5
nsukumar Dec 2, 2010 8:36 PM (in response to svenja-1)Hi,
Double clicking on the '*.swf' file plays the file properly? Can you please share the information on which OS, browser and in Flash player version you are facing the Issue (.htm issue). Can you please confirm that on the colleague’s machine, Flash player ActiveX/Plugin is installed correctly and the location from where they are trying to open the file(.htm) is added as a Flash player trusted location.
What is the error message you are getting when you are trying to Open the *.exe File?.
To fix some 'Publish to .Exe' issues a patch was released. So you can try Publishing to Exe after installing the patch. The details about the patch are blogged here: http://blogs.adobe.com/captivate/2010/08/unable-to-open-exe-files-published-from-adobe-cap tivate-5.html
nsukumar
3. Re: Can't play published projects(*.htm) from Captivate 5
svenja-1 Dec 3, 2010 5:03 AM (in response to nsukumar)Hi nsukumar,
We tried it with different OS (Mac OSX 10.5 - 10.6, Win XP and Win 2007) and different browsers (IE, FF, Safari). Depending on the browser, there is no chance to define this location as an "Flash player trusted location", because either the request is not coming up (but still not plays the movie) or the browsers gets frozen immediately (FF).
On all machines, Flash player ActiveX/Plugin is installed correctly, but we found out that browsers with older version can play the *.htm files:
All browsers, where the plugin was updated to the newest version, wasn't able to play!
The *.exe files just show an black screen when opened on systems without Adobe Captivate installed. I already tried the fix you mentioned, but is still not working.
Svenja
4. Re: Can't play published projects(*.htm) from Captivate 5
svenja-1 Dec 3, 2010 5:05 AM (in response to RodWard)@RodWard
yes, I did that from time to time. But doesn't help.
Svenja
5. Re: Can't play published projects(*.htm) from Captivate 5
nsukumar Dec 5, 2010 8:58 PM (in response to svenja-1)Hi Svenja,
Can you follow the steps mentioned in this blog post and see if that helps.
There was an issue with Cp5 SWF having text animation on latest flash player and the issue is resolved. Blog link : http://blogs.adobe.com/captivate/2010/11/solution-for-cp5-content-not-working-with-the-lat est-flash-player-version.html.
nsukumar.
6. Re: Can't play published projects(*.htm) from Captivate 5
svenja-1 Dec 6, 2010 3:54 AM (in response to nsukumar)Hi nsukumar,
Thanks a lot! That helped now!
Thanks in advance
Svenja
