5 Replies Latest reply on Dec 6, 2010 12:21 PM by GCDufford
    How to create, place, format and paste the clipboard contents into a text frame
    GCDufford
      I am new to scripting and need help. I have an existing Indesign document. I need to be able to create a text frame on my current page, the width of my margins with the top of the text frame at the top margin and 1" in height, then format it to be 1-column, and then paste the clipboard contents into it and tag the text with a particular paragraph style. I am using Indesign CS4 on a mac, if that makes any difference. Thanks for any help.
        • 1. Re: How to create, place, format and paste the clipboard contents into a text frame
          tpk1982 Level 4
          Create a new document with check on "Master Text Frame" in the dialog box. In that dialog box you can enter head margin as well.
          • 2. Re: How to create, place, format and paste the clipboard contents into a text frame
            GCDufford Level 1
            Thanks, but what I am needing is a script that I can either assign a shortcut key to or at least just run from the scripting window. It is a repetitive thing that happens hundreds of times in the documents I am working on. There is already text lower down on the page, and I am cutting part of that text and placing and reformatting it at the top of the page, which has been left blank for this purpose.
            George
            • 3. Re: How to create, place, format and paste the clipboard contents into a text frame
              tpk1982 Level 4
              May this will help you. It will create an anchored object with a text what you desired, with object style. You should create an object style before with the x and y co ordinates. You can choose either para style or character style.
              var the_document = app.documents.item(0);
              // Create a list of paragraph styles
              var list_of_paragraph_styles = the_document.paragraphStyles.everyItem().name;
              // Create a list of character styles
              var list_of_character_styles = the_document.characterStyles.everyItem().name;
              // Create a list of object styles
              var list_of_object_styles = the_document.objectStyles.everyItem().name;
              // Make dialog box for selecting the styles
              var the_dialog = app.dialogs.add({name:"Create anchored text frames"});
              with(the_dialog.dialogColumns.add()){
              with(dialogRows.add()){
              staticTexts.add({staticLabel:"Make the anchored frames from ..."});
              staticTexts.add({staticLabel:"This character style:"});
              var find_cstyle = dropdowns.add({stringList:list_of_character_styles, selectedIndex:0});
              staticTexts.add({staticLabel:"Or this paragraph style:"});
              var find_pstyle = dropdowns.add({stringList:list_of_paragraph_styles, selectedIndex:0});
              staticTexts.add({staticLabel:"Leave one dropdown unchanged!"});
              dialogRows.add();
              staticTexts.add({staticLabel:"Delete matches?"});
              var delete_refs = dropdowns.add({stringList:["Yes","No"], selectedIndex:0});
              dialogRows.add();
              staticTexts.add({staticLabel:"Anchored text frame settings:"});
              staticTexts.add({staticLabel:"Object style:"});
              var anchor_style = dropdowns.add({stringList:list_of_object_styles, selectedIndex:0});
              staticTexts.add({staticLabel:"Frame width:"});
              var anchor_width = measurementEditboxes.add({editUnits:MeasurementUnits.MILLIMETERS, editValue:72});
              staticTexts.add({staticLabel:"Frame height:"});
              var anchor_height = measurementEditboxes.add({editUnits:MeasurementUnits.MILLIMETERS, editValue:72});
              the_dialog.show();
              // Define the selected styles
              var real_find_cstyle = the_document.characterStyles.item(find_cstyle.selectedIndex);
              var real_find_pstyle = the_document.paragraphStyles.item(find_pstyle.selectedIndex);
              var real_anchor_style = the_document.objectStyles.item(anchor_style.selectedIndex);
              // Check if a style is selected
              if(find_cstyle.selectedIndex != 0 || find_pstyle.selectedIndex != 0) {
              // Define whether to search for character styles or paragraph styles
              app.findChangeGrepOptions.includeFootnotes = false;
              app.findChangeGrepOptions.includeHiddenLayers = false;
              app.findChangeGrepOptions.includeLockedLayersForFind = false;
              app.findChangeGrepOptions.includeLockedStoriesForFind = false;
              app.findChangeGrepOptions.includeMasterPages = false;
              if(find_cstyle.selectedIndex != 0) {
              app.findGrepPreferences = NothingEnum.nothing;
              app.findGrepPreferences.appliedCharacterStyle = real_find_cstyle;
              } else {
              app.findGrepPreferences.appliedParagraphStyle = real_find_pstyle;
              app.findGrepPreferences.findWhat = "^";
              // Search the document
              var found_items = the_document.findGrep();
              myCounter = found_items.length-1;
              do {
              // Select and copy the found text
              var current_item = found_items[myCounter];
              if(find_pstyle.selectedIndex != 0) {
              var found_text = current_item.paragraphs.firstItem();
              var insertion_character = (found_text.characters.lastItem().index) + 1;
              var check_insertion_character = insertion_character + 1;
              var alt_insertion_character = (found_text.characters.firstItem().index) - 1;
              var the_story = found_text.parentStory;
              app.selection = found_text;
              if(delete_refs.selectedIndex == 0) {
              app.cut();
              } else {
              app.copy();
              } else {
              var found_text = current_item;
              var insertion_character = (found_text.characters.lastItem().index) + 2;
              var check_insertion_character = insertion_character;
              app.cut();
              } else {
              app.copy();
              // Make text frame from selection
              try {
              app.selection = the_story.insertionPoints[check_insertion_character];
              app.selection = the_story.insertionPoints[insertion_character];
              } catch(err) {
              app.selection = the_story.insertionPoints[alt_insertion_character];
              var the_anchored_frame = app.selection[0].textFrames.add({geometricBounds:["0","0",anchor_height.editContents,anch or_width.editContents],anchoredObjectSettings:{anchoredPosition: AnchorPosition.ANCHORED}});
              app.selection = the_anchored_frame.insertionPoints[0];
              app.paste();
              // Apply the object style now to "force apply" paragraph style set in the object style
              if(anchor_style.selectedIndex != 0) {
              the_anchored_frame.appliedObjectStyle = real_anchor_style;
              myCounter--;
              } while (myCounter >= 0);
              } else {
              alert("No styles selected!");
              • 4. Re: How to create, place, format and paste the clipboard contents into a text frame
                tpk1982 Level 4
                Just copy the script and run. May be this is what you need!!!
                • 5. Re: How to create, place, format and paste the clipboard contents into a text frame
                  GCDufford Level 1
                  Thanks, but you are way too far ahead of me. Just so I can learn, can we take things one step at a time? I've been mostly looking at applescript tutorials, and found one that supposedly does exactly what my first step needs to be (http://www.mactech.com/articles/mactech/Vol.22/22.11/2211AppleScript/index.html):
                  This is the way it reads in the tutorial:
                  tell application "Adobe InDesign CS2"
                     tell page 1 of document 1
                        make new text frame with properties {geometric bounds:{1, 1, 3, 6}}
                     end tell
                  end tell
                  However, when I modify it to fit my circumstance, I get an error message. My script is:
                  tell application "Adobe InDesign CS4"
                      --create text frame at top of active page in active document
                      tell active page of active document
                          make text frame with properties {geometric bounds:{1, 1, 2, 7.75}}
                      end tell
                  end tell
                  When I run the script, it goes to the "make..." line and then returns the error:
                  make with properties {geometric bounds:{1, 1, 2, 7.75}} new text frame
                          --> error number -1708
                  Result:
                  error "Adobe InDesign CS4 got an error: Can’t make class text frame." number -2710 from text frame to class
                  I can't figure out why.
                  George
