0 Replies Latest reply on Dec 2, 2010 12:59 PM by ledroff
    [svn:cairngorm3:] 18981: adding spring-flex and persistence-api to the maven repo
    ledroff Adobe Employee
      Revision: 18981
      Revision: 18981
      Author:   ledroff@adobe.com
      Date:     2010-12-02 12:58:52 -0800 (Thu, 02 Dec 2010)
      Log Message:
      Added Paths:
          cairngorm3/maven-repository/javax/
          cairngorm3/maven-repository/javax/persistence/
          cairngorm3/maven-repository/javax/persistence/persistence-api/
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0/
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0/persistence-api-1.0.jar
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0/persistence-api-1.0.jar .sha1
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0/persistence-api-1.0.pom
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0/persistence-api-1.0.pom .sha1
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0.2/
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0.2/persistence-api-1.0.2 .jar
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0.2/persistence-api-1.0.2 .jar.sha1
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0.2/persistence-api-1.0.2 .pom
          cairngorm3/maven-repository/javax/persistence/persistence-api/1.0.2/persistence-api-1.0.2 .pom.sha1
          cairngorm3/maven-repository/org/springframework/
          cairngorm3/maven-repository/org/springframework/flex/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/mav en-metadata.xml
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/mav en-metadata.xml.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/mav en-metadata.xml.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/spr ing-flex-1.5.0.BUILD-20101202.205147-1.pom
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/spr ing-flex-1.5.0.BUILD-20101202.205147-1.pom.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/1.5.0.BUILD-SNAPSHOT/spr ing-flex-1.5.0.BUILD-20101202.205147-1.pom.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/maven-metadata.xml
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/maven-metadata.xml.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex/maven-metadata.xml.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/maven-metadata.xml
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/maven-metadata.xml.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/maven-metadata.xml.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1-sources.jar
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1-sources.jar.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1-sources.jar.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.jar
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.jar.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.jar.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.pom
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.pom.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/1.5.0.BUILD-SNAPSHO T/spring-flex-core-1.5.0.BUILD-20101202.205146-1.pom.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/maven-metadata.xml
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/maven-metadata.xml. md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-core/maven-metadata.xml. sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/maven-metadata.xml
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/maven-metadata.xml.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/maven-metadata.xml.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/spring-flex-parent-1.5.0.BUILD-20101202.205103-1.pom
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/spring-flex-parent-1.5.0.BUILD-20101202.205103-1.pom.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/1.5.0.BUILD-SNAPS HOT/spring-flex-parent-1.5.0.BUILD-20101202.205103-1.pom.sha1
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/maven-metadata.xm l
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/maven-metadata.xm l.md5
          cairngorm3/maven-repository/org/springframework/flex/spring-flex-parent/maven-metadata.xm l.sha1
