3 Replies Latest reply on Dec 3, 2010 1:17 PM by matthew horn
    Issues using multiple load-config files with ant
    kur1j
      Hello,
      Not sure if this is the correct place...
      I am creating an ant build script to compile our flex application. I am trying to use the default flex-config by doing <load-config filename="${flex.sdkPath}/frameworks/flex-config.xml"/> and project specific config file add the datavisualization module and any other libraries we might need in the future. I am trying to do this as I don't want to modify the flex-config.xml
      The issue I keep running into is I get a compiler error saying "unable to locate specified base class 'spark.comonents.application..". if I place the custome load-config file above the adobe default flex-config it gives errors stating it the "SeriesSlide" type
      <mxmlc file="${project.sourcePath}/FBApp.mxml"
               output="${project.output.binaryPath}/${project.output.fileName}.swf"
               locale="en_US"
               static-link-runtime-shared-libraries="false"
               static-rsls="false"
               use-network="true"
               accessible="false"
               debug="true">
               <load-config filename="C:/Hudson/.hudson/jobs/FB 2.0 Flex/workspace/FBApp/FB-config.xml"/>
               <source-path path-element="${flex.sdkPath}/frameworks/libs"/>
               <source-path path-element="${project.sourcePath}"/>
               <library-path dir="${flex.path}/sdks/${flex.sdkVersion}/frameworks/locale/en_US"
                  includes="*"/>
               <library-path dir="${project.libraryPath}"
                  includes="*"/>
               <keep-as3-metadata name="Protected"/>
            </mxmlc>
      the following is my FB-config.xml
      <?xml version="1.0"?>
      <flex-config>
         <runtime-shared-library-path>
      <path-element>C:\Program Files\Adobe\Adobe Flash Builder 4 Plug-in\sdks\4.1.0\frameworks\libs/datavisualization.swc</path-element>
      <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.1.0.16076/datavisualization_4.1.0.16076.swz</rsl-url>
      <policy-file-url>http://fpdownload.adobe.com/pub/swz/crossdomain.xml</policy-file-url>
      <rsl-url>datavisualization_4.1.0.16076.swz</rsl-url>
      <policy-file-url>.</policy-file-url>
         </runtime-shared-library-path>
      </flex-config>
      It seems to be that the first "load-config" ant runs into is the only one that gets used. When looking around the internet I have multiple cases of where people say they have successfully used multiple load-config files.
      This one in particular.
      If I had to guess on what was wrong I believe my FB-config.xml file is incorrect but I can't find an example of anyones custom configuration file.
      Any guidance would be apprecaited.
