5 Replies Latest reply on Dec 3, 2010 12:25 PM by nstopak
    Problem starting service created from DSC component
    nstopak Level 1
      I downloaded the DSC component tool for use in eclipse and created a very simple component to append messages to a log file.  I then created the component, created a jar file and installed the component in workbench as described in http://www.adobe.com/devnet/livecycle/articles/dsc_development.html.
      Now I can incorporate the component in my process.  So far so good.  Unfortunately when I go to run my process, I get an indication that the service is not running, and sure enough, when I go to the LiveCycle Admin UI I see that the service is stopped.  Unfortunately, when I try to start the service I get the following message:
      MessageLogger Service failed to start
      ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
      which is fine as far as it goes, but doesn't really tell me what I can do to address the problem.  Can anyone suggest next steps to troubleshoot the problem?
      Thanks!
        • 1. Re: Problem starting service created from DSC component
          Jasmin Charbonneau Level 4
          Check the Workbench log to get more information under
          file:///C:/Documents and Settings/Administrator/Workbench ES2/.metadata/.plugins/org.eclipse.ui.workbench/log
          Jasmin
          • 2. Re: Problem starting service created from DSC component
            nstopak Level 1
            Thank you for this suggestion Jasmine.  However,
            a) there is no log file in that folder, only the files "dialog_settings.xml", "workbench.xml" and "workingsettings.xml"
            and
            b) the workbench complains because the services is not started, but the configuration error preventing the service from starting is occurring on the LC server, not in the workbench.  If anything, I'd think the log should be on the LC ES server...
            • 3. Re: Problem starting service created from DSC component
              In Workbench, go under Help/About Adobe LiveCyle Workbench ES2/Configuration Details/View Error Log.
              Jasmin
              • 4. Re: Problem starting service created from DSC component
                nstopak Level 1
                Sorry about the lengthy stack traces.  I've included entries from both the workbench log and the LC Server log.
                Here's the workbench log entry:
                !ENTRY com.adobe.workflow.editor 4 0 2010-12-03 10:47:32.325
                !MESSAGE Error during validation
                !STACK 0
                com.adobe.idp.event.exception.EventTypeDoesNotExistException: An event type by name  does not exist.
                at com.adobe.idp.event.manager.EventManagerImpl.getEventType(EventManagerImpl.java:151)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:597)
                at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:227)
                at sun.reflect.GeneratedMethodAccessor317.invoke(Unknown Source)
                at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
                at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
                at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
                at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
                at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
                at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
                at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
                at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
                at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
                at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
                at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
                at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
                at org.jboss.ejb.Container.invoke(Container.java:960)
                at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
                at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
                at $Proxy158.doSupports(Unknown Source)
                at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
                at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
                at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
                at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
                at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:329)
                at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint. java:139)
                at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java :81)
                at sun.reflect.GeneratedMethodAccessor545.invoke(Unknown Source)
                at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
                at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
                at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
                at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
                at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
                at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
                at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
                at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
                at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
                at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
                at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:290)
                at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
                at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
                at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:235)
                at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
                at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
                at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
                at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
                at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
                at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
                at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
                at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
                at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 157)
                at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
                at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
                at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
                at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
                at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
                at java.lang.Thread.run(Thread.java:619)
                Here's the error from the LC Server log:
                2010-12-03 10:50:23,056 ERROR [com.adobe.repository.ui.aac.struts.actions] failed.to.start.service
                java.lang.IllegalStateException: Component: gov.doj.ustp.logging version:1.0 must be in a running state prior to starting service: MessageLogger version: 1.0
                at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.start(ServiceRegistryImpl.jav a:1930)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
                at sun.reflect.GeneratedMethodAccessor298.invoke(Unknown Source)
                at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
                at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
                at $Proxy159.doBMT(Unknown Source)
                at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
                at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:165)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
                at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
                at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryCli ent.java:996)
                at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.invoke(ServiceRegistryCli ent.java:991)
                at com.adobe.idp.dsc.registry.service.client.ServiceRegistryClient.start(ServiceRegistryClie nt.java:632)
                at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(Start ServiceConfigurationsAction.java:110)
                at com.adobe.repository.ui.aac.struts.actions.CommandProcessorAction.execute(CommandProcesso rAction.java:228)
                at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
                at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
                at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
                at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
                at com.adobe.repository.ui.aac.AacServletFilter.doFilter(AacServletFilter.java:137)
                at com.adobe.framework.SecurityFilter.doFilter(SecurityFilter.java:206)
                at com.adobe.framework.SessionBundleFilter.doFilter(SessionBundleFilter.java:135)
                at com.adobe.repository.ui.aac.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java :76)
                2010-12-03 10:50:23,056 ERROR [com.adobe.repository.ui.aac.struts.actions] aac.action.unknownerror
                com.adobe.repository.ui.aac.AacException: ALC-AAC-0017-000: Service(s) failed to start. It could be configuration problem.
                at com.adobe.repository.ui.aac.struts.actions.StartServiceConfigurationsAction.execute(Start ServiceConfigurationsAction.java:133)
                • 5. Re: Problem starting service created from DSC component
                  nstopak Level 1
                  Solved it.  Apparently I needed to start the component in Workbench, and then I was able to start the server on the LC Server.  I think it will take me another component or two to get the process down.
