8 Replies Latest reply on Dec 5, 2010 6:20 AM by Steve Grisetti
    APE 9 Demo
    neophema1@gmail.com
      Installed, and seems to produce quality output, however the view of the imported files is jumpy. Audio is fine, video is not. Like I said, the saved files seem ok, but editing is challenging.
      Shut down everything I could think of, but still seems to lag.
      Vista 64 sp2 (tuned off super fetch, caching, indexing, etc.)
      2.5 ghz dual core
      4 gig ram
      plenty of free disk space
      nvidia GeForce 7100/nForce 630i native
        • 1. Re: APE 9 Demo
          the_wine_snob Level 9
          Welcome to the forum.
          What are the full specs. of the source files, and also your Project Preset, established when you do New Project?
          Also, for some media, there are elements that are not in the trial, but are included and activated with the full-paid version.
          • 2. Re: APE 9 Demo
            neophema1@gmail.com Level 1
            Ok, here goes!
            Not sure how to glean presets - a New project is listed as:
            "NTSC-AVCHD_AVCHD LITE 720p60"
            APE9 did asked me if I wanted to match the "project settings" to the file type, and I selected "yes".
            Does this help?
            General
            Complete name                    : C:\Videos\100VIDEO\HDV_0024.MP4
            Format                           : MPEG-4
            Format profile                   : JVT
            Codec ID                         : avc1
            File size                        : 1.54 GiB
            Duration                         : 35mn 51s
            Overall bit rate                 : 6 138 Kbps
            Writing library                  : SEC
            @sec                             : UNG
            Video
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : Main@L4.2
            Format settings, CABAC           : Yes
            Format settings, ReFrames        : 4 frames
            Format settings, GOP             : M=3, N=15
            Codec ID                         : avc1
            Codec ID/Info                    : Advanced Video Coding
            Duration                         : 35mn 51s
            Bit rate mode                    : Variable
            Bit rate                         : 5 995 Kbps
            Width                            : 1 280 pixels
            Height                           : 720 pixels
            Display aspect ratio             : 16:9
            Frame rate mode                  : Variable
            Frame rate                       : 59.940 fps
            Minimum frame rate               : 59.920 fps
            Maximum frame rate               : 59.960 fps
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Progressive
            Bits/(Pixel*Frame)               : 0.109
            Stream size                      : 1.50 GiB (98%)
            Title                            : HMX200
            Language                         : English
            Audio
            Format                           : AAC
            Format/Info                      : Advanced Audio Codec
            Format version                   : Version 4
            Format profile                   : LC
            Format settings, PS              : Yes
            Codec ID                         : 40
            Duration                         : 35mn 51s
            Bit rate mode                    : Constant
            Bit rate                         : 128 Kbps
            Channel(s)                       : 2 channels
            Channel positions                : Front: L R
            Sampling rate                    : 48.0 KHz
            Compression mode                 : Lossy
            Stream size                      : 32.8 MiB (2%)
            Title                            : HMX200
            Language                         : English
            • 3. Re: APE 9 Demo
              What model of camcorder did this video come from?
              You're getting some strange behavior that seems to indicate that you may be using video from an unsupported camcorder source.
              Also, if you go to Edit/Project Settings, what settings does the project show (since it apparently updated when you imported your video.)?
              • 4. Re: APE 9 Demo
                It's a Samsung HMX-H200BN-XAA and less than two months old.
                • 5. Re: APE 9 Demo
                  From the spcs page for this camcorder, it looks like it may only shoot true AVCHD in 1920x1080 Fine or Superfine mode. I'd recommend you see if that video will work with the 1920x1080 AVCHD project preset.
                  The 1280x720p may or may not be completely compatible.
                  • 6. Re: APE 9 Demo
                    Ted Smith Level 3
                    Assuming you fix you projrct compatibility, If you render the project is the preview still jumpy? Check you have no red lines at the top of the timeline.
                    This has been covered in numerous posts in this forum.
                    I have a similar powered computer using XP
                    I had some jumpiness on preview when I first installed everything on one disk, also stuttering of audio.
                    I split it up so the video is on a separate disk to everything else - much smoother but not perfect
                    Original disk was 2 disks in Raid 1(parallel backup mode)
                    Split that up to two seperate disks. Went smoother again.
                    Put OS & Program on one disk, all project files on second and only imported video on the third.
                    Now shuttles, edits instantly & perfectly smooth in preview once rendered over complicated effects.
                    I'm using full AVCHD 1920X1080i that is more demanding than yours.
                    Seems like PE doesn't like reading and writing to the same disk at the same time
                    • 7. Re: APE 9 Demo
                      I don't think your recommendation is to reshoot in 1920x1080, but to use that as a project preset.  I did and as I load the file,  APE9  suggests I change my preset to match the imported video. Just for a drill I said no, and the unedited playback is the same, jumpy.
                      As mentioned before, the project saves to a file that does play normally, no jump/jitter. The challenge is loading a file from the camcorder (downloaded from camcorder to disk) and simply hitting the "play" button. It is painful to watch, and equally difficult to edit.
                      I did notice the 1920x1080 preset produced some noise around the edges of moving objects - in the saved file.
                      • 8. Re: APE 9 Demo
                        No, I am recommending that, at least until you get this sorted out, you try shooting in Super Fine 1920x1080 and set up your Premiere Elements project with a matching preset. See if that solves your problems.
                        The problem with these multi-format camcorders is that some formats do and some formats don't work with Premiere Elements. So you need to start with a known quantity first.
