7 Replies Latest reply on Nov 16, 2011 9:15 AM by insuractive
    cfdocument with cfpdfform - odd behavior
    SteveTX Level 1
      I'm trying to create a pdf that display some content from HTML and then includes a pdf form file, and I am experiencing two odd things:
      1. The content in the cfdocumentsection above the cfpdfform tag does not show up in the pdf. All I see is the pdf form.
      2. If I try to save the cfdocument using the filename attribute, it doesn't work. The file is not created and the pdf form displays in the browser. If I remove the cfpdfform tag, then the file is created and I see the content from the cfdocumentsection in the result.
      Anyone have any ideas what is going wrong? The code looks like this:
      <cfdocument format="pdf">
          <H2>PDF Form</H2>
          <cfpdfform action="populate" source="#request.path.file_directory##attributes.fileid#.pdf" xmldata="#setInputXMLRet.result#" overwritedata="true">
