3 Replies Latest reply on Dec 12, 2010 3:01 PM by Andrian Cucu
    Proxy Plugin
    Coco213
      Hello,
      I'd like to know if, in a proxy plugin, we have access to the MediaContainer which is containing the proxied media element ?
      Best regards
        • 1. Re: Proxy Plugin
          Andrian Cucu Adobe Employee
          Hi Coco213,
          A ProxyPlugin doesn't have access to the MediaContainer. You can try and pass a reference to the MediaContainer if you need it. I suppose you would pass it as Plugin Resource metadata and handle it in the initialize method.
          Check the plugin user guide for details: http://osmf.org/dev/osmf/OtherPDFs/osmf_plugin_dev_guide.pdf
          -Andrian
          • 2. Re: Proxy Plugin
            Coco213 Level 1
            Hi Adrian,
            Thanks for your answer, but I don't really understand how to pass a Plugin Ressource Metadata in the initialize method.
            The chapter in the plugins guide about the initialize method is quite small, there is no example about how to do that ... do you have any snippet ?
            Thanks !
            Regards
            Coco213
            • 3. Re: Proxy Plugin
              Here is a player side snippet (it might contain spelling errors, i didn't check it with a compiler).
              var pluginResource = new URLResource("http://myserver.com/myplugin.swf");
              pluginResource.addMetadataValue("username", "myusername");
              pluginResource.addMetadataValue("password", "mypassword");
              var mediaFactory:MediaFactory = new DefaultMediaFactory();
              mediaFactory.... add events listeners
              mediaFactory.loadPlugin(pluginResource);
              Here is a snippet in a PluginInfo side:
              * SingleSignOnPluginInfo will read the username and password from the plugin metadata
              * and will create a SingleSignOnProxyElement that would handle the auth.
              public class SingleSignOnPluginInfo extends PluginInfo
              public const SSO_USERNAME:String = "username";
              public const SSO_PASSWORD:String = "password";
              public function SingleSignOnPluginInfo()
              var items:Vector.<MediaFactoryItem> = new Vector.<MediaFactoryItem>();
              var item:MediaFactoryItem = new MediaFactoryItem("org.osmf.plugin.singlesignon",
              canHandleResource,
              createMediaElement,
              MediaFactoryItemType.PROXY);
              items.push(item);
              super(items);
              override public function initializePlugin(resource:MediaResourceBase):void
              username = resource.getMetadataValue(SSO_USERNAME) as String;
              password =  resource.getMetadataValue(SSO_PASSWORD) as String;
              // Internals
              private var username:String;
              private var password:String;
              * Handles everything
              private function canHandleResource(resource:MediaResourceBase):Boolean
                   return username != null && password != null;
              * Creates a new MediaElement and sets on it the plugin metadata
              private function createMediaElement():MediaElement
              var mediaElement:MediaElement = new SingleSignOnProxyElement(null, username, password);
              return mediaElement;
