1 Reply Latest reply on Dec 5, 2010 3:07 PM by rfrishbe
    MobileItemRenderer states
    fransfx
      ItemRenderer supports standard states, such as Normal, Hovered, and Selected.
      Does MobileItemRenderer also support some subset of those states?
      Thanks!
        • 1. Re: MobileItemRenderer states
          rfrishbe Level 3
          ItemRenderer is designed to be primarily used in MXML.  Because of that we support states.
          However, MobileIconItemRenderer is primarily used in ActionScript.  Because of that, we don't see a huge reason to support states.  If you want to know whether you are selected or not, look at the selected property.  Same with down.
          The only reason I can think of to support states would be to allow AdvancedCSS styling.
          Is there another reason you have for wanting states?
          If you file an enhancement request with your use-case, it's something we'll consider, but we'll have to weight it against the perfromance cost associated with states.
          -Ryan
