1 Reply Latest reply on Jul 30, 2007 7:21 AM by Newsgroup_User
    NetConnection Problem
    Level 7
      Hi everyone,
      I'm having an issue with NetConnection when trying to play back a
      streaming video and I'm hoping someone has had some experience with this
      problem. Basically I'm trying to stream videos from Akamai. I've been
      using Akamai for a number of months now and understand the entire edge
      server detection streaming thing. In Flash 8 I never encountered any
      issues. I've very recently started porting my code to ActionScript 3
      because I'm rewriting the player for Flash 9. Now, however, after
      detecting the edge server the NetConnection object simply rejects every
      connection I try to make. The exact info message is
      "NetConnection.Connect.Rejected". I wasn't sure if it was a security
      error (which isn't being thrown or broadcast) or if it's really a server
      thing, so I ran a web debugging proxy to watch traffic between my
      computer and the server. Oddly, Flash never attempts the connection to
      Akamai, it simply rejects the connection attempt. It doesn't try to
      retrieve a crossdomain XML file, doesn't throw any errors, doesn't
      broadcast any errors, or do anything else. Essentially, the .connect
      method simply results in a "NetConnection.Connect.Rejected" status event.
      I have read in a few different places that connections may be closed if
      there are too many being made (for example, FlashComm server with too
      many users). This is not the case; like I said, the connection is never
      even attempted. I also thought that it may be a security sandbox thing.
      I ran it on our testing site, locally, from a local web server, a
      variety of remote web servers....nothing. The same result came coming
      back. The player simply refused to attempt the connection. No
      crossdomain file was requested but other connections to the same server
      (like URLLoader) went through just fine. Other than the syntax
      differences and using URLLoader instead of LoadVars, there are no major
      differences between the Flash 8 video player and the Flash 9 video
      player. With Flash 8 I can see all the connections going through,
      requests for crossdomain files....the whole bit. With Flash 9, the
      NetConnection connect request simply does nothing; absolutely nothing.
      Incidentally, I've also tried this with progressive download videos
      (same code, just connecting to NULL) and they play fine.
      I have to admit I'm completely baffled. Does anyone have any ideas? Is
      this a bug with CS3 or am I doing something wrong? Has the "connect"
      method changed drastically between versions so that the same string
      parameter is no longer valid?
      Many thanks,
      Patrick
        • 1. Re: NetConnection Problem
          Level 7
          Anyone? I've been hitting this thing for over a week now and still
          nothing. I've also tried streaming from other sites (FlashComm/Media
          Server) and also no go. NetConnection doesn't try connecting. There is
          no request made, no domain name resolution. The sequence of events is:
          NetConnection.connect -> Rejected
          There are no actions in between, no errors thrown, no errors broadcast.
          Nothing to indicate that anything has gone wrong or that the address is
          incorrect or that there is a security violation of some sort. Nothing at
          all. I'm really out of ideas at this point...has anyone experienced this
          and, if so, were you able to fix it (and how)?
          Thanks again,
          Patrick
          Patrick B wrote:
          > Hi everyone,
          > if there are too many being made (for example, FlashComm server with too
          > Is this a bug with CS3 or am I doing something wrong? Has the "connect"
          > Many thanks,
          > Patrick
          http://www.baynewmedia.com
          Faster, easier, better...ActionScript development taken to new heights.
          Download the BNMAPI today. You'll wonder how you ever did without it!
          Available for ActionScript 2.0/3.0.
