3 Replies Latest reply on Dec 6, 2010 10:16 AM by Flex harUI
    Flex 3 locale swf loading bug on firefox
    cosmits
      Hi all
      I REALLY need your help here
      if anyone knows this bug or have any idea how to deal with it, it would really mean a lot to me
      i've been tring everything
      description:
      i'm building an application using flex 3, where all texts are being localized via the locale loaded at runtime
      i suspect that for some reason the  locale swf i'm loading isn't updating elements of the page
      as you can see in the image below, texts appear cut off.
      this happens to me only in firefox, no matter which page of the app is being displayed
      any ideas?
      appreciate your time in answering
      Yariv Gilad
        • 1. Re: Flex 3 locale swf loading bug on firefox
          Flex harUI Adobe Employee
          Is it the right text?  If so, the locale SWF is loaded properly and there is
          a sizing or positioning problem.
          • 2. Re: Flex 3 locale swf loading bug on firefox
            cosmits Level 1
            Hello and thank you for your quick answer
            the text is indeed right, and what you say make sense to me
            how can i proceed from here though?
            how can i fix the "sizing and positioning problem" ?
            the UI components are there and are being populated dynamically through the locale
            is there a way to force them to update?
            is this the right direction at all?
            any other ideas?
            just to note that if i hard-code the text into the components they are rendered perfectly
            so i don't see a reason to change their position or size...
            thank you for your time
            Yariv Gilad
            • 3. Re: Flex 3 locale swf loading bug on firefox
              My favorite trick is to set a breakpoint on FocusManager.as:mouseDownHandler
              and click on whatever it you want to examine, then examine its properties.
              I've seen things like this when spaces are not 0x20 but 0xA0, or when the
              width is just a few pixels too narrow and causes wordwrap, or when there is
              leading whitespace in the text.
