1 Reply Latest reply on Dec 6, 2010 11:21 AM by GordonSmith
    Flex tip: conditions like ‘&&’ in MXML in MXML part
    manpakhong Level 1
      Consider the following little MXML snippet:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
              <mx:VBox x="0" y="0" height="100%" width="100%">
                      <mx:CheckBox label="Checkbox 1" id="check1"/>
                      <mx:CheckBox label="Checkbox 2" id="check2"/>
                      <mx:Label text="{check1.selected && check2.selected?
                              'Both checked':
                              'Not both checked'}"/>
              </mx:VBox>
      </mx:Application>
      We want to show the string “Both checked” in the label, if both of  the checkboxes are checked, otherwise the label should show “Not both  checked”. When you use the above code in Flex, it will show you the  error: “The entity name must immediately follow the ‘&’ in the  entity reference.”. It is complaining about the line where the  “&&” appears.
      MXML files are treated as XML files and as such the parser expects to  see a symbol name after the “&” character. Hence the error message.
      With this in mind, we can convince Flex Builder and the mxml-compiler  to still use “&&” as a condition, by properly escaping them, as  in:
                      <mx:Label text="{check1.selected &amp;&amp; check2.selected?
                              'Both checked':
              </mx:VBox>
      </mx:Application>
      The above may look weird in the editor, but it compiles cleanly and does what one would expect.
      The same applies to other operators: “< " should be written as "&lt;" and ">” should be written as “&gt;”.
      manpakhong@hotmail.com
      manpakhong
      Man Pak Hong, Dave
