0 Replies Latest reply on Dec 5, 2010 5:28 AM by deivit_78
    variable detecting change
    deivit_78
      Hello, i'm learning about flex and actionscript and now i'm creating two components, one is a dropDownlist that is connecting to a database and shows several values, this one is ok. The value selected is returned to the main application, and this send as a parameter to the second component. The problem is: how can i detect the change of this parameter inside of the second component?.
      I was done http://livedocs.adobe.com/flex/3/html/help.html?content=databinding_7.html
      but this does not work for me.
      I put the second component code below:
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:mx="library://ns.adobe.com/flex/mx" width="514" height="156"
               creationComplete="init()">
          <fx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.binding.utils.*;
                  import mx.events.FlexEvent;
                  [Bindable]
                  public var p_grupo:String;
                  private function init():void
                      var watcherSetter:ChangeWatcher =
                          BindingUtils.bindSetter(watcherListener, id_label, "text");
                  public function watcherListener(val:String):void {
                          id2_label.text =val;
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Label id="id_label" x="145" y="61" text="{p_grupo}"/>
          <s:Label id="id2_label" x="145" y = "80" text="" />
      </s:Group>
      Why update the id_label data, but not is detecting the change?
      Thanks for a lot
