2 Replies Latest reply on Dec 6, 2010 5:05 AM by srini_7206
    How to remove spritevisualelement from group
    srini_7206
      I have drawn triangles using spritevisualelement and added that to Group.But when I try to remove the previously plotted elements using array ,those are not atually removed from the group instead the triangles are still visible.How to make them to be deleted from the Group.So that I can draw new triangles without overlapping.
      var tempArr:Array=[];
      function drawTriangles():void{
      for each(var item:SpriteVisualElement in tempArr){
           if(grpChart.contains(item)){
                     grpChart.removeElement(item);
      var sprite:SpriteVisualElement=new SpriteVisualElement();
      sprite.graphics.clear();
      sprite.graphics.lineStyle();
      sprite.graphics.beginFill();
      sprite.graphics.moveTo();
      sprite.graphics.lineTo();
      sprite.graphics.endFill();
      grpChart.addElement(sprite);//grpChart is Group
      tempAr.push(sprite);
      Srini
        • 1. Re: How to remove spritevisualelement from group
          Shongrunden Adobe Employee
          Can you provide a small sample application that demonstrates this?  For example this seems to work fine for me:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <fx:Script>
                  <![CDATA[
                      import spark.core.SpriteVisualElement;
                      private var mySVE:SpriteVisualElement;
                      protected function addSVE():void {
                          mySVE = new SpriteVisualElement();
                          mySVE.graphics.clear();
                          mySVE.graphics.beginFill(0x0000FF);
                          mySVE.graphics.drawRect(0,0,100,100);
                          mySVE.graphics.endFill();
                          myGroup.addElement(mySVE);
                      protected function removeSVE():void {
                          myGroup.removeElement(mySVE);
              </fx:Script>
              <s:controlBarContent>
                  <s:Button label="add" click="addSVE()" />
                  <s:Button label="remove" click="removeSVE()" />
              </s:controlBarContent>
              <s:Group id="myGroup" />
          </s:Application>
          • 2. Re: How to remove spritevisualelement from group
            srini_7206 Level 1
            Thank you Shongrunden,
            I am able to remove the spritevisualelement from group by using removeElementAt() method.
            But I am getting another issue as ,
            I am plotting the triangles on the group.When I drag slider then the  group is zoomed.In this view I am redrawing all the triangles.But some times at maximum zoomed level the triangles are not redrawn.What will be the issue.
            Srini
            Message was edited by: srini_7206
