0 Replies Latest reply on Dec 6, 2010 1:30 AM by ledroff
    [svn:cairngorm3:] 19050: minor updates : ignore files, FB files and header. txt
    ledroff Adobe Employee
      Revision: 19050
      Revision: 19050
      Author:   ledroff@adobe.com
      Date:     2010-12-06 01:30:06 -0800 (Mon, 06 Dec 2010)
      Log Message:
      minor updates : ignore files, FB files and header.txt
      Modified Paths:
          cairngorm3/trunk/libraries/ContractTest/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationDMS/.actionScriptProperties
          cairngorm3/trunk/libraries/Module/.actionScriptProperties
          cairngorm3/trunk/libraries/ModuleTest/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationParsleyTest/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationParsleyTest/.flexProperties
          cairngorm3/trunk/libraries/NavigationSpringAS/.settings/com.adobe.flexbuilder.project.pre fs
          cairngorm3/trunk/libraries/NavigationSpringAS/.settings/org.eclipse.core.resources.prefs
          cairngorm3/trunk/libraries/NavigationTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Popup/.actionScriptProperties
          cairngorm3/trunk/libraries/Popup/.flexLibProperties
          cairngorm3/trunk/samples/insync/insync-basic/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-basic/.flexProperties
          cairngorm3/trunk/samples/insync/insync-basic/.project
          cairngorm3/trunk/samples/insync/insync-modularExtended-api/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-contacts/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-contacts/.flexProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-contacts/.project
          cairngorm3/trunk/samples/insync/insync-modularExtended-expenses/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-expenses/.flexProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-expenses/.project
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/.flexProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-messaging/.project
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/.actionScriptProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/.flexProperties
          cairngorm3/trunk/samples/insync/insync-modularExtended-shell/.project
      Added Paths:
          cairngorm3/trunk/libraries/Navigation/.FlexUnitSettings/
          cairngorm3/trunk/libraries/Navigation/.FlexUnitSettings/FlexUnitApplicationLastRun.xml
          cairngorm3/trunk/src/conf/
          cairngorm3/trunk/src/conf/header.txt
      Removed Paths:
          cairngorm3/trunk/libraries/ContractTest/html-template/
          cairngorm3/trunk/libraries/ModuleTest/html-template/
      Property Changed:
          cairngorm3/trunk/
          cairngorm3/trunk/libraries/Contract/
          cairngorm3/trunk/libraries/IntegrationParsley/
          cairngorm3/trunk/libraries/NavigationParsley/
          cairngorm3/trunk/libraries/NavigationSpringASTest/
          cairngorm3/trunk/libraries/NavigationSwiz/
          cairngorm3/trunk/libraries/NavigationSwizTest/
          cairngorm3/trunk/libraries/PopupParsley/
          cairngorm3/trunk/samples/todo/
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_android/
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_core/
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_remoting_dto/
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_test/
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_todolist_lib/
          cairngorm3/trunk/samples/todo/todo_java/
          cairngorm3/trunk/samples/todo/todo_java/todo_java_persistence/
          cairngorm3/trunk/samples/todo/todo_java/todo_java_remoting_service/
          cairngorm3/trunk/samples/todo/todo_java/todo_webapp/
