Hi to all,
I create a Form using Adobe LiveCycle Designer 8.2. The purpose of this form is to have multiple digital signatures from 4 different people. But when the first person fills the form and does a digital signature. The second, third and forth cannot do the digital signature. I’m the only one that can do the rest of the digital signature. I try many thinks like lock and unlock the signature field without any luck. Please if someone can let me know what I can do will appreciate. Thanks.
Solved! Go to Solution.
Views
Total Likes
That's correct. Reader can only be used to sign PDFs that have been "Reader Extended". This can be done with LiveCycle Reader Extensions ES2, or in cases where (I think) less than 500 people will be using the "extended" document, Acrobat Professional can be used to enable signatures with Reader.
Regards
Steve
Views
Total Likes
Did you enable\disable the "Lock Fields After Signing" option for the signature field(s)? (see screen shot)
Did you configure any seed values for the signaturte field(s)
Can you post a copy of the the form?
Reagrds
Steve
Views
Total Likes
Thanks Steve,
Yes, I try disable and enable the “Lock Fields after Signing” and I also create a custom one but it doesn’t work.
No, I didn’t configure any seed values. Do I have to? If, so how can I do it?
How can I post the copy? I try to do a screen shot but it was to big....
Alex
Views
Total Likes
Steve,
This is the form.
Alex
Views
Total Likes
I took a quick look at the form, it appears to be working fine. I am able to sign it (using Acrobat), and then subsequently sign the remaining signature fields.
Are you using Acrobat to do the testing? Remember, you can't sign a PDF with Adobe Reader unless the form has been Reader Extended to enable Adobe Reader to sign PDFs.
Regards
Steve
Views
Total Likes
From "alexvj"
Yes, I have Acrobat, but the user have only Adobe reader. So I just need to change it to reader extended?
Alex
Views
Total Likes
Regards
Steve
Views
Total Likes
It work!!! Thank you so much Steve....:)
Views
Total Likes
