1 Reply Latest reply on Dec 6, 2010 7:30 AM by JohnDevlon
    Identifying and Replacing Tagged Text
    mlavie Level 1
      I have a TextFrame full of text. Different portions of the text are marked with different Tags.
      I want to identify the various runs of text by the Tag which marked them, and replace the content of that Tagged run of text according to its Tag using my business logic.
      For example, for the tags
      Tag1
      Tag2
      Tag3
      And the following Tagged text (I am including the square brackets which InDesign adds around Tagged text runs)
      [Vini][Vidi][Vici]
      I would like to be able to identify that
      "Vini" is marked by Tag1 (and should be replaced by "Ars")
      "Vidi" is marked by Tag2 (and should be replaced by "Gratia")
      "Vici" is marked by Tag3 (and should be replaced by "Artis")
      And then perform the replacement, giving:
      [Ars][Gratia][Artis]
      How would I go about this?
        • 1. Re: Identifying and Replacing Tagged Text
          JohnDevlon Level 1
          look at the xmlelements ... that's the key to succes...
          What i would try to do is ...
          1. Loop over every PageItem
          2. Retreive the associated XML element
          3. Do a recursive search within all sub xmlelements
          4. check the name of every XML element
          5. If it's the correct XML element, change the content property to the new value
          for (var b = 0; b < myDoc.allPageItems.length; b++){
                 var myXMLelement = myDoc.allPageItems[b].associatedXMLElement;
                ProcessXMLelement(myXMLelement);
          function ProcessXMLelement(elm){
                 // Get the name of the Tag
                myTagName = elm.markupTag.name.toString();
               if (myTagName == "myTag"){
                         elm.contents = "New Text";
                 // Process all sub elements
                 for (var i = 0; i < elm.xmlElements.length; i++){
                      ProcessXMLelement(elm.xmlElements[i]);
          Hopefully this helps
          John
