7 Replies Latest reply on Dec 7, 2010 12:10 PM by Flex harUI
    Datagrid and verticalScrollPosition
    aciam70
      Hello everyone
      I have a datagrid with an editable column.
      When I enter in an editable cell, automatically a new position of vertical scroll bar is set.
      Why?
      How can I prevent it?
        • 1. Re: Datagrid and verticalScrollPosition
          Flex harUI Adobe Employee
          Are you editing the last row?  Or a row that is taller than the visible
          area?  Otherwise it shouldn't shift.
          • 2. Re: Datagrid and verticalScrollPosition
            aciam70 Level 1
            Hi, thanks for your kind answer, but  my  problem is: every row that I'm editing, it automatically get up, and take the  first visible position in the data grid.
            Of course it happens when there are many other visible rows
            How can I set the row always at the same position?
            • 3. Re: Datagrid and verticalScrollPosition
              saisri2k2 Level 4
              Yup, Ive seen this behaviour in the list as well, when I use checkbox as a custom itemrenderer, and the user clicks the checkbox, the list will scroll automatically, is it because the list height is small?? i have only 3 rows being shown.
              • 4. Re: Datagrid and verticalScrollPosition
                Do you have a custom editor?  Try a simple example with the default editor
                and see if you have the same problem.
                • 5. Re: Datagrid and verticalScrollPosition
                  If you have a small example, post it.
                  • 6. Re: Datagrid and verticalScrollPosition
                    aciam70 Level 1
                    Here my example:
                                   xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                        <fx:Declarations>
                            <!-- Place non-visual elements (e.g., services, value objects) here -->
                        </fx:Declarations>
                        <fx:Script>
                            <![CDATA[
                                import mx.collections.ArrayCollection;
                                import mx.events.DataGridEvent;
                                import mx.events.ListEvent;
                                private var gacSorting:ArrayCollection  = new ArrayCollection([
                                    {OrigID:"0", OrigCutoff:"", Deadline:"00:00", Editing:"0"},
                                    {OrigID:"1", OrigCutoff:"00:00", Deadline:"", Editing:"0"},
                                    {OrigID:"2", OrigCutoff:"01:00", Deadline:"", Editing:"0"},
                                    {OrigID:"3", OrigCutoff:"02:00", Deadline:"", Editing:"0"},
                                    {OrigID:"4", OrigCutoff:"03:00", Deadline:"", Editing:"0"},
                                    {OrigID:"5", OrigCutoff:"04:00", Deadline:"", Editing:"0"},
                                    {OrigID:"5", OrigCutoff:"04:00", Deadline:"", Editing:"0"}]);
                                protected function SortingChangeHandler(event:ListEvent):void
                                    if(gacSorting[event.rowIndex].OrigID == "0")
                                        dgcDeadlineSort.editable = true;
                                        dgcOrigCutoffSort.editable = false;
                                    else
                                        dgcDeadlineSort.editable = false;
                                        dgcOrigCutoffSort.editable = true;
                                protected function ItemEditBeginningHandler(event:DataGridEvent):void
                                    gacSorting[event.rowIndex].Editing = 1;
                                    gacSorting.refresh();
                        </fx:Script>
                        <mx:DataGrid id="dgSorting" width="90%" height="24%"
                                     selectable="true" allowMultipleSelection="false"
                                     dataProvider="{gacSorting}" editable="true"
                                     change="SortingChangeHandler(event)"
                                     itemEditBeginning="ItemEditBeginningHandler(event)">
                            <mx:columns>
                                <mx:DataGridColumn id="dgcOrigID" dataField="OrigID" textAlign="center" editable="false" headerText="Orig ID"/>
                                <mx:DataGridColumn id="dgcOrigCutoffSort" dataField="OrigCutoff" textAlign="center" editable="true" headerText="Cut off"/>
                                <mx:DataGridColumn id="dgcDeadlineSort" dataField="Deadline" textAlign="center" editable="true" headerText="Deadline"/>
                            </mx:columns>
                        </mx:DataGrid>
                    </s:Application>
                    If I comment "gacSorting.refresh();" inside itemEditBeginning, it works correctly.
                    Why?
                    • 7. Re: Datagrid and verticalScrollPosition
                      I didn't have time to run your test case, but it looks like you are changing
                      the data as the editor comes up.  That might cause your problem.
