33 Replies Latest reply on Dec 14, 2010 5:07 PM by brandonkboswell
    Shooting for Colormetric Accuracy of Fine Artwork
    brandonkboswell Level 1
      Good Morning,
      I have been shooting pieces of artwork for my clients with a 5D mk2 and have been striving for better color accuracy. I have been using the Colorchecker to generate DNG Profiles for the camera in my studio. When I open images in ACR and I set my tonal values to specific values to match the chart I get drastically different numbers on the info pallete in PS CS5 than on the tone curve in ACR. I do have Photoshop set to use ProPhoto RGB in 16bit. Why is this happening and how can I solve this?
      Thank you,
      Brandon
        • 1. Re: Shooting for Colormetric Accuracy of Fine Artwork
          MadManChan2000 Adobe Employee
          Is your working space in ACR (see Workflow Options dialog box) set to ProPhoto as well?
          • 2. Re: Shooting for Colormetric Accuracy of Fine Artwork
            Yes, Full Resolution, ProPhoto, 16-bit
            • 3. Re: Shooting for Colormetric Accuracy of Fine Artwork
              I have no explanation for this.
              Can you please show screenshots of your ACR dialog showing the color samplers (and their numeric readouts), as well as of your Photoshop window with corresponding samplers & numeric readouts?
              I would like to double-check that there isn't a missed setting somewhere.
              • 5. Re: Shooting for Colormetric Accuracy of Fine Artwork
                Vit Novak Level 3
                Hm ... wouldn't it be better to use linear tone curve in the profile, than linearizing default adobe tone curve ?
                • 6. Re: Shooting for Colormetric Accuracy of Fine Artwork
                  I have tried both, but shouldn't a tonal value in Photoshop be reasonably similar to the one I chose in ACR?
                  • 7. Re: Shooting for Colormetric Accuracy of Fine Artwork
                    Vit Novak Level 3
                    I'm not sure that I understand what you mean by difference here.
                    If you mean a small difference between RGB value of the patch #1, which is 242,247,230 by sampling tool and 243, 248,232 as you specified in PS, this is probably caused by different position and/or size of sample between these programs. Don't know about PS, but in ACR, this number isn't a value of single pixel, but average of small area around it. So the small difference is caused by noise in the image
                    Or you had something else in mind and I missed the point ?
                    • 8. Re: Shooting for Colormetric Accuracy of Fine Artwork
                      Patch 1 is the only patch that is reasonably close to the ACR output values.
                                           ACR                                 PS
                      Patch 2          189                         175,178,170
                      Patch 3          144                         125,127,123
                      Patch 4          101                           85,86,82
                      Patch 5           67                            53,53,53
                      Patch 6           37                            28,28,28
                      The variance appears to be much larger than noise. Especially since the avgs in PS are consistently lower than ACR.
                      • 9. Re: Shooting for Colormetric Accuracy of Fine Artwork
                        Vit Novak Level 3
                        I see. Looks like difference between sRGB and PhotoPro values
                        Anyway, I tried opening similar test raw image, set Photo Pro color space, then opened it in PS, but in my case values shown in ACR and PS are very similar
                        But wait ... for instance patch #3, you have 127,128,125 shown by ACR tool and 125,127,123 specified on other picture. Where did you get 144 for ACR ?
                        • 10. Re: Shooting for Colormetric Accuracy of Fine Artwork
                          The 144 number comes from the number on the Point Curve. That's not the correct number to look at, because it is an intermediate value (in the middle of the processing pipeline).
                          The correct number to look at is the color sampler as shown across the top of the ACR bar. That represents the final output color, at the end of the processing.
                          All of these numbers roughly match the ones in PS, so I do not see any discrepancy.
                          • 11. Re: Shooting for Colormetric Accuracy of Fine Artwork
                            I see now. I will use the numbers at the top from now on. I should also be using a linear profile as well correct?
                            Just curious, what other processing is being applied after the tone curve?
                            Thank you very much for you help!
                            • 12. Re: Shooting for Colormetric Accuracy of Fine Artwork
                              Vit Novak Level 3
                              According to dng documentation, applying of tone curve is at the end of pipeline, before converting from Photo Pro to final color space (in your case, there's no such conversion, as you selected Photo Pro as output color space). So I pressume that if you leave all sliders at neutral, that would mean that tone curve is at the end of pipeline in ACR also
                              Anyway, be aware that you don't see actual tone curve that will be applied. It is a combination of tone curve in the selected profile (which is usually S-shaped), modification of tone curve in ACR Tone curve section and some of sliders in the basic section (brightness, contrast ...)
                              • 13. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                Couldn't agree with you more, but wouldn't this mean that if I created a custom DNG profile based on a linear tone curve, set all the basic adjustments to 0 or their neutral values, and set no Parametric tone settings that the tonal curve value should match the values once exported to PS CS5?
                                This is ultimately the workflow I would like to set up.
                                • 14. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                  Vit Novak Level 3
                                  Well, my knowledge about color science and color management is actually quite limited. Someone with better knowledge about this relatively complex subject would probably give you better or more accurate advice than me
                                  From what I know, typical workflow with digital camera is to transform a capture of the scene to an image that would be displayed on the monitor or printed on the paper. Since dynamic range and color gamut of the scene is usually way larger than of the monitor or paper, image has to be severely tweaked ("rendered") to get pleasant result, while colorimetric accuracy is not very important. This typically involves compressing of the highlights with a tone curve and and some changes of hue and saturation with a big 3D lookup table (+ whitebalancing and changes of color space)
                                  If I understand correctly, what you need is to use your 5D as a kind of scanner, to accurately capture a "scene" that is already on the "output media" with limited dynamic range and color gamut and under controlled lighting. So, these rendering tweaks have to be relatively small, just to compensate for some nonlinearity in the whole process. In other words, tone curve of the whole process should be close to linear and lookup table mustn't introduce huge hue/saturation/brightness shifts
                                  To get linear tone curve of the whole ACR pipeline, you need:
                                  - profile with linear tone curve
                                  - ACR settings: brightness +50, contrast +25, tone curve = medium-contrast
                                  - about blacks slider, default value is said to be +5, while my experiments shown me that it has to be 0, so I'm not sure
                                  - other sliders like saturation, vibrancy, recover, fill light etc should be 0
                                  • 15. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                    klsteven-zl2JzT
                                    Couldn`t you just make a custom profile with the DNG profile editor? This should
                                    get you as close as possible to the original colors.
                                    • 16. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                      I'm working for as close of match as possible to a fine art original. I have found that creating a custom DNG Profile is only but a small part in this complex process. Even with a proper DNG profile the native tone-curve, brightness and contrast in ACR will cause even a good capture to print badly.
                                      • 17. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                        For minimal ACR processing, you should use:
                                        Brightness = 0
                                        Contrast = 0
                                        Blacks = 0
                                        Point Curve = Linear
                                        Sharpening (Amount) = 0
                                        Noise Reduction (Amount) = 0
                                        Everything else at defaults.
                                        This gets you as close to scene-referred as ACR currently permits.
                                        (And be warned this will usually make your images look pretty bad. This is expected behavior.)
                                        • 18. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                          Vit Novak Level 3
                                          Eric, are you absolutely sure about these settings ?
                                          Or with another words, if I have a profile that contains only color and forward matrix, linear tone curve but no lookup table, will ACR with these settings return the same result as simple mathematical conversion from sensor color space to PCS using WB multipliers from raw file and forward matrix from profile, followed by conversion to output color space ? Because in my experiments, it turned out that it won't - I got exact match with settings that I wrote (it was quite strange finding, but I suppose there are some historical reasons for this)
                                          • 19. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                            Jeff Schewe Level 5
                                            Yeah, I'm pretty sure Eric knows what he's talking about...he works on Camera Raw ya know?
                                            • 20. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                              Vit Novak Level 3
                                              Of course I know, Jeff
                                              I just want to make sure that we were both talking about the same thing, because - default settings for all profiles is brightness 50 contrast 25, and, what's even more strange, my own profiles for Canon cameras with CHDK are giving exact match with jpeg from camera at the very same position of brightness and contrast, and they were calculated with my code, without any usage of DNG profile editor or dng sdk code (where function of brightness and contrast slider are unfortunately not documented), so it was very strange why they don't match jpegs at brightnes 0 contrast 0
                                              • 21. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                sandy_mc Level 3
                                                Vit,
                                                The work I've done confirms exactly what Eric said. The emphasis is however on "as close to scene-referred as ACR currently permits".......
                                                Sandy
                                                • 22. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                  Vit Novak Level 3
                                                  I believe that there could be some misunderstanding between me and Eric + there are things in color management that I don't understand correctly
                                                  Maybe I ask another question (that posssibliy has different answer): what are the settings in ACR that mean applying no tone curve at all in the whole pipeline, but just conversion from sensor color space to destination color space (which includes gamma encoding to nonlinear output color space, that comes at the end of the workflow, documented in dng sdk) - lIke in some freeware programs, for instance dcraw ?
                                                  • 23. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                    sandy_mc Level 3
                                                    Vit,
                                                    From a DNG SDK perspective, you can set up the tags in the image such that the pipeline will be in either PCS or scene referred "mode"; what you are talking about is PCS, which sets the processing pipeline not to do the curves, shadow compensation, etc that would be done if the image was scene referred. All raw images are by ACR definition scene referred however.
                                                    But that's only useful to know if you're writing code that uses the SDK - it doesn't help the OP's problem.
                                                    Sandy
                                                    • 24. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                      Vit Novak Level 3
                                                      Hm, it looks like I'll have to study this subject in greater detail ...
                                                      However, if I get this correctly, what boswellbk is trying to do is making a dng profile by shooting color checker and then trying to correct tone curve, so that grayscale values produced by ACR, using that profile, match the values specified for that color checker (in Photo Pro color space), at least numbers chosen on tone curve have the same values. Is my guess correct? Is this the right aproach for what he need ?
                                                      • 25. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                        sandy_mc Level 3
                                                        Vit,
                                                        It is possible to set up either Lightroom or ACR to match the color checker, including the effects of the tone curve - I did so, (actually I did so for Lightroom, C1 and Aperture!) back in 2008 - see the multi-part blog post here. Note that in addition to what I describe in the 2008 articles, you'd also need to use a camera profile without hue twists; those didn't exist back then.
                                                        The problem is, as Eric said above, that "accurate" color (aka color without a tone curve) looks terrible!!!!! The original paper on why this is the case, and why the shape of the tone curve needs to be what it is, is "General-Purpose Gamut-Mapping Algorithms: Evaluation of Contrast-Preserving Rescaling Functions for Color Gamut Mapping", Gustav J. Braun and Mark D. Fairchild. Although no doubt Adobe and other have done more recent work.
                                                        So I think the original poster is (sorry) on a high road to nowhere in terms of trying to remove the tone curve; it just means the end result will look bad. What can be done is calibrate to the values for the color checker adjusted for a tone curve. That's about as close (in my opinion anyway) as you can get to "scientifically accurate" color repoduction. Of course, you'd also need all the viewing condition stuff done right.
                                                        Sandy
                                                        • 26. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                          Vit Novak Level 3
                                                          Hm, I'm still not getting this completely, but doesn't matter, I'll read some books about this
                                                          Anyway, I'll try to repeat my question in one another form:
                                                          Suppose I have a dng profile with a tone curve defined (whether adobe tone curve, or some other tone curve in some Camera profile, or linear tone curve or whatever). What are the positions of ACR sliders that will ensure that THIS curve in profile would be used in the ACR pipeline without any corrections/distorsions/brigtening/darkening/change of contrast/whatever ?
                                                          And another question:
                                                          If I just want to simulate a scanner with my digital camera, what would be the right approach for this, so that ACR output will match output of a scanner (that has been profiled etc)?
                                                          • 27. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                            Hi Vit, yes, the settings I described are correct, with the following exceptions:
                                                            1. There is no way to disable (i.e., turn off) a color profile's lookup tables, if any. So if you have selected a color profile that contains a lookup table, it will still be active.
                                                            The only way to avoid this processing is to select a profile that does not contain any lookup table. You can do this, for example, by making a copy of a profile that has a lookup table (e.g., "Adobe Standard"), and removing all tables from the copy (e.g., using code that you write).
                                                            2. There is no way to disable (i.e., turn off) a color profile's tone curve, if any. So if you have selected a color profile that contains a custom tone curve, it will still be active.
                                                            3. Some camera models have a non-zero BaselineExposure tag by default (e.g., -0.25). For a given model, the easiest way to determine this value is to convert an image to a DNG, and use a reader (e.g., dng_validate, exiftool, etc.).
                                                            To eliminate the associated processing, you need to set Exposure to the opposite of the BaselineExposure tag. For example, if the tag value says -0.25, you would need to set the Exposure to +0.25.
                                                            I hope this helps.
                                                            Eric
                                                            • 28. Re: Shooting for Colormetric Accuracy of Fine Artwork
                                                              Hi Vit, I understand your question about the profile's tone curve.
                                                              ACR is set up so that its default control settings, listed below, will give you exactly what is contained in the profile:
                                                              - Brightness = 50
                                                              - Contrast = 25
                                                              - Point Curve = Medium
                                                              So, if you've built a custom DNG profile that has its own custom tone curve, you will get exactly that tone curve by setting the above ACR controls to the stated values.
                                                              If the custom DNG profile does not contain a custom tone curve, then you will simply get the default ACR tone curve.
                                                              If you wish to avoid other ACR processing, then you will need to disable those controls as well (e.g., as stated in earlier posts, this means setting Blacks to 0 and adjusting Exposure, etc.).
                                                              • 29. Re: Shooting for Colormetric Accuracy of Fine Artwork
        Vit Novak Level 3
        Thank you very much for this excelent and clear explanation, Eric. Yes, it is exacty what I have found out so far
        I think I understand now why you mentioned brightnes=0, contrast=0, blacks=0, linear tone curve settings to get as close as possible to scene-referred.It is true for a profile with default ACR tone curve (or a profile without a tone curve), as these settings seem to have counter-effect of default ACR tone curve and resulting tone curve of the whole pipeline is linear. However, if I have a profile with custom tone curve, the same settings won't result with linear tone curve of the whole pipeline. That was the reason of misunderstanding I think
        Can you confirm this ?
        • 30. Re: Shooting for Colormetric Accuracy of Fine Artwork
        Hudechrome Level 2
        I've been reading this with interest, and it forced be into the color literature where I spent a good part of my morning, getting definitions straight etc. As I look over the comments, it occurred to me that I also had a fine art shoot recently, only one image, but I solved it by using two gray patches about one stop apart, shot under diffuse daylight  and set the patches to neutral in ACR. The result was excellent, my client surprised and pleased.
        Were I doing a studio shoot in which many different products samples subjects that had to output as high end representations, I would be using the same method you folks do, but with respect to images of objects that  do not come close to pushing gamut and tonal ranges (usually!) why this concern with producing a custom profile? I automatically run ProPhoto as my color space. The painting I shot showed zero change when converting to sRGB, using the web viewing function in PS.
        This isn't a criticism, I would like to know more about it vis a vis fine art reproduction problems and how this implements the solutions.
        Lawrence
        • 31. Re: Shooting for Colormetric Accuracy of Fine Artwork
        You are exactly correct, Vit.
        Originally, when I was discussing Brightness = 0, Contrast = 0, etc., I had assumed that the color profile did not contain a custom tone curve.
        • 32. Re: Shooting for Colormetric Accuracy of Fine Artwork
        So let me make sure I have this right. If I have created a custom DNG profile with a linear tone curve I choose 0 for my brightness and contrast or the default 50 and 25?
