17 Replies Latest reply on Dec 8, 2010 11:06 PM by rahuls9009
    Adobe you are SO DAMN SLOPPY ... my Flash Catalyst install on Win 7
    VirtualCoder Level 1
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 23 error(s), 28 warning(s)
      WARNING: The payload with AdobeCode:  {E8815668-95B0-443D-AC92-2BFD7DD8F16A} has recommended dependency on:
      WARNING: Family: Adobe Web Suite CS5
      WARNING: ProductName: Adobe Media Encoder CS5 X64
      WARNING: MinVersion: 0.0.0.0
      WARNING: This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
      WARNING: Removing this payload from the dependency list.
      WARNING: Payload {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE} Adobe Flash Player 10 Plugin is already installed and the session payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin has no upgrage/conflict relationship with it.
      WARNING: Payload {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7} Adobe Flash Player 10 ActiveX is already installed and the session payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX has no upgrage/conflict relationship with it.
      WARNING: OS requirements not met for {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
      WARNING: Payload cannot be installed due to dependent operation failure
      ERROR: Verifying payload integerity : Failed with code 1
      ERROR: MsiConfigureProductEx failed with error: 1603
      ERROR: The following payload errors were found during install:
      ERROR:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR:  - Adobe Media Player: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR:  - Adobe Player for Embedding: Install failed
      ERROR:  - Suite Shared Configuration CS5: Install failed
      ERROR:  - AdobeHelp: Install failed
      ERROR:  - Adobe Flash Player 10 Plugin: Install failed
      ERROR:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR:  - Adobe Media Encoder CS5: Install failed
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  - Adobe Flash Fonts1: Install failed
      ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
      ERROR:  - Microsoft_VC80_CRT_x86: Install failed
      ERROR:  - DynamiclinkSupport: Install failed
      ERROR:  - AdobeCMaps CS5: Install failed
      ERROR:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR:  - Adobe Flash Catalyst CS5: Install failed
      ERROR:  - Adobe AIR: Install failed
