8 Replies Latest reply on Dec 7, 2010 4:11 AM by Stephen Horne
    How to give commands to items of a list (Applescript)
    Stephen Horne Level 1
      I'm confused by something I've come across in indesign scripting. I'm making a list of page items from a selection, then sorting it into sublists, to each of whish I would like to pass commands. Once I've made them into lists, however, I always get an error if I try to pass a command to that list.
      Here is a condensed example:
      tell application "Adobe InDesign CS5"
      set itemList to selection
      set list1 to {item 1 of itemList, item 2 of itemList}
      set list2 to {item 3 of itemList, item 4 of itemList}
      tell list1
      set name to "test"
      end tell
      end tell
      or
      set name of list1 to "test"
      end tell
      both give me an error, but if I tell the selection itself (also a list, no?) it works, eg:
      set name of selection to "test"
      end tell
      or, infuriatingly:
      select list2
      end tell
      so I can select the items using a list, but not much else.
      Does anyone know what's happening here?
      Thanks.
        • 1. Re: How to give commands to items of a list (Applescript)
          sstanleyau Level 4
          You can't send a command to a list; your script is seen as trying to set the name of a list, and that can't be done.
          Once you start addressing the selection,you're addressing a single InDesign identity -- the fact that it returns a list of items is irrelevant.
          • 2. Re: How to give commands to items of a list (Applescript)
            Aha. That's a shame.
            Thanks for the help.
            • 3. Re: How to give commands to items of a list (Applescript)
              sstanleyau Level 4
              It's not that bad -- you can still act on multiple items at once. It's just that you can't specify them as a list, usually. But you can do something like "set name of page items of aGroup to"blah"".
              • 4. Re: How to give commands to items of a list (Applescript)
                Thanks Shane, I've gone with selecting the list of items, then setting the name of the selection. Not very neat, but it serves the purpose. I'll post the finished script in case it's of interest to anyone.
                It's a bodge to get around the way items that are grouped "forget" their original layers once ungrouped. Please enlighten me if I'm missing something; I've not posted anything about it, just searched in vain.
                It comprises two scripts. I bind the first to cmd-G, and the second to cmd-shift-G in ID,replacing the standard "group" and "ungroup" shortcuts.
                It's a bodge because it uses the "name" property of page items to store the previous layer name. The other option was the "label" property, but I use that, and don't use the name one. An earlier incarnation saved the string value of the name in there too, fixing it to how it was on the ungroup, but this got shaved out in some streamlining.
                script 1:
                set oldDelims to AppleScript's text item delimiters
                set theNameList to name of selection
                set theItemLayerList to item layer of selection
                set theDocumentLayerNameList to name of layers of active document
                set theDocumentLayerList to layers of active document
                set itemLayerBreakdown to {}
                repeat with i from 1 to count theDocumentLayerList
                set end of itemLayerBreakdown to {}
                end repeat
                repeat with i from 1 to count theItemLayerList
                repeat with j from 1 to count theDocumentLayerList
                if item i of theItemLayerList is item j of theDocumentLayerList then
                set end of item j of itemLayerBreakdown to (item i of itemList)
                end if
                end repeat
                end repeat
                repeat with i from 1 to (count itemLayerBreakdown)
                if item i of itemLayerBreakdown is not {} then
                set layerName to (item i of theDocumentLayerNameList)
                select item i of itemLayerBreakdown
                tell selection
                set name to layerName
                end tell
                end if
                end repeat
                try
                set theNewGroup to make new group in active document with properties {group items:itemList}
                on error number 30477
                select itemList
                set lockedItems to items of selection whose locked is true
                select lockedItems
                display dialog "Selected items are locked and cannot be grouped."
                return
                end try
                select theNewGroup
                end tell
                set AppleScript's text item delimiters to oldDelims as text
                script 2:
                set itemList to page items of selection
                ungroup selection
                select itemList
                end repeat
                repeat with i from 1 to count theNameList
                if item i of theNameList is item j of theDocumentLayerNameList then
                end if
                end repeat
                end repeat
                repeat with i from 1 to (count itemLayerBreakdown) -- to 1 by -1
                move selection to item i of theDocumentLayerList
                end if
                end repeat
                select itemList
                end tell
                • 5. Re: How to give commands to items of a list (Applescript)
                  sstanleyau Level 4
                  You might consider using insert label instead -- a bit more effort, but more robust than names. OTOH, if you're happy with names you can do it a bit more easily. Have a look at these snippets:
                  set usedNames to {}
                  set theNames to name of item layer of items of selection
                  repeat with i from 1 to count of theNames
                  set aName to item i of theNames
                  if usedNames does not contain aName then
                  set name of (every item of selection whose name of item layer is aName) to aName
                  set end of usedNames to aName
                  end if
                  end repeat
                  end tell
                  set theItems to page items of selection
                  ungroup selection
                  set selection to theItems
                  set usedNames to {}
                  set theNames to name of items of selection
                  log (get every item of selection whose name is aName)
                  set item layer of (every item of selection whose name is aName) to layer aName of document 1
                  end if
                  end repeat
                  end tell
                  • 6. Re: How to give commands to items of a list (Applescript)
                    These are a bit tidier, thanks Shane. The second one doesn't quite work as is, because of the "set item layer of (every item of selection whose name is aName) to layer aName of document 1", this muddles up the ordering of the page items for some reason. After much messing around with reversing the list before setting the item layer of the items within, I realised that a "move selection to layer…" moved them all without messing up their relative indexes.
                    When you say insert label, is that a document label, rather than a per-item label? I've had a look in the dictionary and found the insert label command, is this what you mean? Create a document-based list of groups and their items?
                    Stephen Horne
                    • 7. Re: How to give commands to items of a list (Applescript)
                      sstanleyau Level 4
                      No, you can have them on items. They are key-based -- you can set as many as you like for an item -- and they don't appear anywhere in the UI. That means you have to know the key to retrieve or overwrite them. They're a bit more work to use, but they are much more robust.
                      • 8. Re: How to give commands to items of a list (Applescript)
                        Great! I'm just reading up on this now. Exciting stuff!
                        Thanks for the pointers.
