5 Replies Latest reply on Dec 7, 2010 3:33 AM by Jeff Bellune
    Exporting Problem
    ManndarrPat Level 1
      Hello everyone,
      I am having some serious exporting for 2nd time, I am working on 720x486 23.976 fps, and then I am trying to export the by checking MATCH SETTING BOX in the exporting setting  window format in Microsoft AVI said file and it suddenly stopped in ENCORE and showed following error :
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT.prproj
      - Output File: G:\Sequence 01_4.mpg
      - Preset Used: Custom
      - Video: PAL, 720x576, 25 fps, Quality 4.0, Lower
      - Audio: MPEG, 224 kbps, 48 kHz, 16 bit, Stereo
      - Bitrate: VBR, 1 Pass, Min 2.50, Target 4.20, Max 6.00 Mbps
      - Encoding Time: 00:03:10
      13/09/2010 9:44:14 PM : Encoding Failed
      Error compiling movie.
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_1.prproj
      - Output File: G:\ganpati bappa morya.mpg
      - Encoding Time: 00:05:02
      13/09/2010 9:50:41 PM : Encoding Failed
      The Operation was interrupted by user
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_2.prproj
      - Output File: G:\Sequence 01_1.mpg
      - Encoding Time: 00:01:42
      13/09/2010 9:59:34 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_3.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\Shivraj 1.mpg
      - Encoding Time: 00:31:39
      13/09/2010 10:41:38 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_4.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\Sequence 01.f4v
      - Preset Used: F4V - Match Source Attributes (High Quality)
      - Video: 1280x720, Same as source fps, Progressive
      - Audio: AAC, 128 kbps, 44.1 kHz, Stereo
      - Bitrate: VBR, 1 Pass, Target 4.50 Mbps, Max 5.40 Mbps
      - Encoding Time: 00:01:39
      13/09/2010 10:45:05 PM : Encoding Failed
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_5.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\Sequence 01_1.f4v
      - Encoding Time: 00:04:23
      13/09/2010 11:11:02 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\shivraj tarun mandal 14 9_1.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\shivraj PAL.m2v
      - Preset Used: Match Source Attributes (High Quality)
      - Video:
      - Audio:
      - Bitrate:
      - Encoding Time: 00:23:57
      14/09/2010 11:19:14 AM : Encoding Failed
      - Source File: C:\Users\Mandar\AppData\Local\Temp\shivraj tarun mandal 14 9_2.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\shivraj tarun mandal dvd.m2v
      - Audio: Dolby Digital, 192 kbps, 48 kHz
      - Bitrate: VBR, 1 Pass, Min 2.80, Target 5.00, Max 7.00 Mbps
      - Encoding Time: 00:02:02
      14/09/2010 2:56:36 PM : Encoding Failed
      - Source File: C:\Users\Mandar\AppData\Local\Temp\shivraj tarun mandal 14 9_3.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\Sequence 01.m2v
      - Preset Used: PAL High Quality
      - Audio: PCM, 48 kHz, 16 bit, Stereo
      14/09/2010 2:59:06 PM : Encoding Failed
      - Source File: C:\Users\Mandar\AppData\Local\Temp\shivraj tarun mandal 14 9_5.prproj
      - Output File: G:\SHIVRAJ DEC FINAL OUTPUT\Sequence 01.mpg
      - Video: PAL, 720x576, 25 fps, Quality 3.5, Lower
      14/09/2010 3:35:16 PM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_6.prproj
      - Output File: G:\Sequence 01.mpeg
      - Preset Used:
      - Video: 1280x720, 25 [fps], Progressive, Quality 50
      - Audio: 48000 Hz, Stereo, 16 bit
      - Bitrate:
      - Encoding Time: 00:04:47
      16/09/2010 9:28:47 AM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\FInal OUT PUT_7.prproj
      - Output File: G:\Sequence 01_5.mpeg
      - Preset Used:
      - Bitrate:
      - Encoding Time: 00:01:13
      21/09/2010 2:15:21 AM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\1st edit.prproj
      - Output File: G:\Master.avi
      - Preset Used:
      - Video: 720x480, 23.98 [fps], Progressive, Quality 100
      - Bitrate:
      - Encoding Time: 00:02:38
      07/12/2010 4:13:44 AM : Encoding Failed
      Unknown error.
      - Source File: C:\Users\Mandar\AppData\Local\Temp\1st edit_1.prproj
      - Output File: H:\American Cinema Editors\OUTPUT\1st Rough Edit.mp4
      - Video: PAL, 720x576, 25 fps, Progressive
      - Audio: AAC, 192 kbps, 48 kHz, Stereo
      - Bitrate: VBR, 1 Pass, Target 6.00, Max 10.00 Mbps
      - Encoding Time: 00:02:32
      07/12/2010 4:19:58 AM : Encoding Failed
      Unknown error.
      AFTER THIS MESSAGE I TRIED WITH H.264 AND AGAIN ENCORE STOPPED EXPORTING THE SAID FILE IT ALSO SHOWED FOLLOWING ERROR MESSAGE
      Unknown error.
      Unknown error.
      Unknown error.
      Unknown error.
      - Video:
      - Audio:
      - Bitrate:
      Unknown error.
      - Preset Used:
      - Bitrate:
      Unknown error.
      - Preset Used:
      - Bitrate:
      Unknown error.
      - Preset Used:
      - Bitrate:
      Unknown error.
      Unknown error.
      PLEASE HELP ME how I can solve this problem ? If any one need any information I am ready to provide you....
      Any help would be highly appreciated
      Thank you in advance
        • 1. Re: Exporting Problem
          ManndarrPat Level 1
          Hello Everyone
          I am having some serious exporting problem for 2nd time, I am working on 720x486 23.976 fps, and then I am trying to export the said file by checking MATCH SETTING BOX in the exporting setting  window format in Microsoft AVI but after few minutes the said file suddenly stopped exporting and showed following error :
          Unknown error.
          Unknown error.
          Unknown error.
          Unknown error.
          - Video:
          - Audio:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          Unknown error.
          Unknown error.
          Unknown error.
          Unknown error.
          Unknown error.
          - Video:
          - Audio:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          - Preset Used:
          - Bitrate:
          Unknown error.
          Unknown error.
          • 2. Re: Exporting Problem
            ManndarrPat Level 1
            HERE IS A message showed in AAF EXPORT LOG :-
            The AAF file "H:\American Cinema Editors\OUTPUT\Rough 1\1st edit.aaf" could not be exported completely and/or accurately, as logged below:
            Cannot export video transition "ADBE Dip To White" (Sequence: "Master", Video Track: "Video 1" (#1), Position: 927, Time: 00:00:38:15) because it is not supported. Transition was replaced by a Video Dissolve.
            Cannot export video transition "ADBE Dip To White" (Sequence: "Master", Video Track: "Video 1" (#1), Position: 4381, Time: 00:03:02:13) because it is not supported. Transition was replaced by a Video Dissolve.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2R-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\CardboardRips.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2L-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Ar-15 Automatic Rifle 2 Sin.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo32.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\BoxCardboard.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-7 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo19.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Juicy Stab.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\_Stab.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo27.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-6 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SwishShingSlice02.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2D-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2L-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Horror Head Crunch.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1A-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo9.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Office_bg.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2G-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2A-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2W-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2B-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\_BodyHitsCompilation.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-6 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "\\?\H:\American Cinema Editors\1st cut\1B-6 (A) Audio Extracted.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3D-2.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1D-4.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2R-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SigPistolGunshotInt.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\PE03-31_RifleEcho.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-7 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Gun9mmGlockShot.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\Music\ending door close.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\Music\Untitled Multitrack 1.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "\\?\H:\American Cinema Editors\1st cut\1-5 (B) Audio Extracted.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3-4.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo7.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3B-5.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SwishShingSlice11.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-6.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2F-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1D-1.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo10.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2K-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-8 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo17.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Architect office OS.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-8 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2F-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo18.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2D-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2B-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2A-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2-3. (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1A-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo23.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2A-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-6 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2U-7 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2C-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2G-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo25.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3B-4.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2H-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo3.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-6 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Multiple Crunchy Fist Impac.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2W-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SwishShingSlice03.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2W-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Blade Shing Ring off.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo15.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2U-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2F-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\357MagnumFire.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1A-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3A-3.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2B-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Architect office.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Knife Stab Gore.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1A-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\PistolShotsInt.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-4.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2T-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-7 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-6 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo4.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo28.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo5.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshSwordSingle.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2W-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2K-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2D-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1D-2.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2A-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Sword shing combo3.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-6 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2R-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo8.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2D-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SwishShingSlice07.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2L-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo12.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2U-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2N-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo11.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo20.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo31.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\357 Magnum Pistol Shot 1 Cl.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3A-4.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2Q-7 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2R-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-7 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2C-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3D-3.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3C-5.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-9 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2H-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo24.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo6.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\MerlinElectPhoneRing.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2C-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3B-1.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\AluminumSwishes.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2K-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-9 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo21.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2G-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo14.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1B-6 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo26.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Sword_ Swish1.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Metal Head Hit.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\357MagnumFire.wav.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3D-5.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\SwishShingSlice14.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1-5 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2U-7 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo13.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2F-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo16.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2G-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-6 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Sword_ Swish2.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 3\3B-2.mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo34.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-7 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo33.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2P-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2E-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo30.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2K-1 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 1\1C-3 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\OfficeWallaLitePROD.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2C-2 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2-2 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2M-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2B-1 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-4 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Merlin DblRing.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2V-5 (A).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\Sword_ Fight Sequence.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2J-4 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2S-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio because "H:\American Cinema Editors\Assets\Sequence 2\2L-3 (B).mov" also contains video. Only audio-only media files can be embedded.
            Cannot embed audio source "H:\American Cinema Editors\Assets\SFX_ACE\WhooshCombo29.wav" because an error occurred when writing essence data. Premiere ASL error number: -2147483647.
            • 3. Re: Exporting Problem
              Jeff Bellune Level 5
              We, as users, don't really need the entire contents of your log files.  You've included log entries from September.  It's simply too much information.
              You don't want to use the Match Sequence Settings check box.  I discuss it in my tutorial here:
              http://bellunevideo.com/tutdetail.php?tutid=16
              -Jeff
              • 4. Re: Exporting Problem
                ManndarrPat Level 1
                Thank you Jeff for quick reply, your tutorials is gr8
                I tried on several codecs also like H.264, AVI but at the end it showed error and it stops
                I really don't know whats wrong with my Adobe Premiere Pro whenever I tried to export any file, error occurred, its really very bad,
                Please help me out,
                It only renders 70% to 82% sequence and then it suddenly stops, now every time I am trying to export,  this error will occur
                M uploading screen shot also please help me I am fed up with this problem
