7 Replies Latest reply on Oct 6, 2011 6:29 AM by wliter
    LabelGraphics from contextual menu crashes OS X CS4 ID
    joesickspack Level 1
      I am trying to use the LabelGraphics script by first running the LabelGraphicsMenu script (which installs the Label Graphic menu item on the contextual menu that pops up for selected graphics) and then selecting Label Graphic item from the contextual menu.
      I assume this will only create labels for selected graphics instead of every graphic in the document.
      Unfortunately, when I select Label Graphic from the menu it crashes ID. I've tried the AppleScript and the javaScript with the same result. Does anyone know how to fix this or why it would be happening?
        • 1. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
          wliter
          It also crashes in windows 7
          did you ever get an answer ?
          Problem signature:
            Problem Event Name:    APPCRASH
            Application Name:    InDesign.exe
            Application Version:    6.0.6.622
            Application Timestamp:    4caa28e2
            Fault Module Name:    WidgetBin.dll
            Fault Module Version:    6.0.6.622
            Fault Module Timestamp:    4caa289d
            Exception Code:    c0000005
            Exception Offset:    000fbb95
            OS Version:    6.1.7601.2.1.0.256.1
            Locale ID:    1033
            Additional Information 1:    0a9e
            Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
            Additional Information 3:    0a9e
            Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
          Message was edited by: wliter
          • 2. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
            I think I ended up using a script that applied labels to everything and then deleting the unwanted ones.
            • 3. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
              John Hawkinson Level 5
              wliter, those Event reports from Windows are essentially meaningless (:-().
              The only useful item from them is the faulting module.
              I reproduced this on a Mac under CS5 and we get this stack trace:
              Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
              0   ???                               0xa06416f0 _XHNDL_trapback_instruction + 0
              1   ...adobe.InDesign.AppFramework    0x1f126923 GetPlugIn + 7155
              2   ...adobe.InDesign.AppFramework    0x1f12ffa7 GetPlugIn + 45687
              3   ...adobe.InDesign.AppFramework    0x1f130569 GetPlugIn + 47161
              4   PublicLib.dylib                   0x0124fde9 CSubject::Change(IDType<ClassID_tag>, IDType<PMIID_tag> const&, void*) + 89
              5   WidgetBinLib.dylib                0x0288896b MWindow::CloseWindow() + 811
              6   ...obe.InDesign.Application UI    0x1fecccb7 GetPlugIn + 305415
              7   ...obe.InDesign.Application UI    0x1fecc6a5 GetPlugIn + 303861
              8   PublicLib.dylib                   0x01164422 Command::DoImmediate(short) + 34
              9   com.adobe.InDesign.Utilities      0x202e5aa3 0x202e4000 + 6819
              10  com.adobe.InDesign.Utilities      0x202e5ccc 0x202e4000 + 7372
              11  ...adobe.InDesign.AppFramework    0x1f11a688 0x1f100000 + 108168
              12  ...adobe.InDesign.AppFramework    0x1f10cf11 0x1f100000 + 53009
              13  ...adobe.InDesign.AppFramework    0x1f102f0e 0x1f100000 + 12046
              14  ...adobe.InDesign.AppFramework    0x1f1284fa GetPlugIn + 14282
              15  com.adobe.InDesign                0x000028ab main + 187
              16  com.adobe.InDesign                0x000027c6 start + 54
              So apparently it's trying to close a window, and then something else breaks. Huh.
              • 4. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
                wliter Level 1
                Yes John -  I have no idea why this has been out there for so long.
                How does one get this fixed ?
                I appears in CS4 CS5.5 in Windows and Mac
                -Walter
                • 5. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
                  Open a case with Adobe Support http://adobe.com/go/supportportal.
                  If you don't have the resources to do so, then use http://adobe.com/go/wish.
                  • 6. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
                    wliter Level 1
                    Thank you
                    Submited  let's see if we get a fix or an answer
                    -Walter
                    • 7. Re: LabelGraphics from contextual menu crashes OS X CS4 ID
                      wliter Level 1
                      Looks like this is a dead issue - It seems that the Abobe Indesign team is not interested in fixing their own problems ...
