0 Replies Latest reply on Dec 7, 2010 4:45 AM by ledroff
    [svn:cairngorm3:] 19093: Eclipse/FB files refactoring
    ledroff Adobe Employee
      Revision: 19093
      Revision: 19093
      Author:   ledroff@adobe.com
      Date:     2010-12-07 04:44:39 -0800 (Tue, 07 Dec 2010)
      Log Message:
      • migrated to FB burrito
        • please use the same flex sdk as in the build files : Flex Hero (build 17855)
        • import and declare it as such in your FB settings
      • deleted all the duplicated entries in the various libs folders
      • replaced those entries by linked resources (you now have to create a link resource folder M2_REPO pointing either
        • the C3 repo found in c3 svn depot
        • or to your local maven repo
      • deleted unnecessary html template in the test projects
      • simplified the fb files to include all classes in the library by default
      Modified Paths:
          cairngorm3/trunk/libraries/Contract/.actionScriptProperties
          cairngorm3/trunk/libraries/Contract/.flexLibProperties
          cairngorm3/trunk/libraries/ContractTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationDMS/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationDMS/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationTest/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationTest/.flexProperties
          cairngorm3/trunk/libraries/Module/.actionScriptProperties
          cairngorm3/trunk/libraries/Module/.flexLibProperties
          cairngorm3/trunk/libraries/ModuleTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Navigation/.actionScriptProperties
          cairngorm3/trunk/libraries/Navigation/.flexLibProperties
          cairngorm3/trunk/libraries/NavigationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationParsley/.flexLibProperties
          cairngorm3/trunk/libraries/NavigationParsleyTest/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationParsleyTest/.flexProperties
          cairngorm3/trunk/libraries/NavigationSpringAS/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationSpringAS/.flexLibProperties
          cairngorm3/trunk/libraries/NavigationSpringAS/.project
          cairngorm3/trunk/libraries/NavigationSpringASTest/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationSwiz/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationSwiz/.flexLibProperties
          cairngorm3/trunk/libraries/NavigationSwizTest/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Observer/.actionScriptProperties
          cairngorm3/trunk/libraries/Observer/.flexLibProperties
          cairngorm3/trunk/libraries/ObserverParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/ObserverParsley/.flexLibProperties
          cairngorm3/trunk/libraries/ObserverTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Persistence/.actionScriptProperties
          cairngorm3/trunk/libraries/Persistence/.flexLibProperties
          cairngorm3/trunk/libraries/PersistenceTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Popup/.actionScriptProperties
          cairngorm3/trunk/libraries/Popup/.flexLibProperties
          cairngorm3/trunk/libraries/PopupParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/PopupParsley/.flexLibProperties
          cairngorm3/trunk/libraries/PopupTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Task/.actionScriptProperties
          cairngorm3/trunk/libraries/Task/.flexLibProperties
          cairngorm3/trunk/libraries/TaskTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Validation/.actionScriptProperties
          cairngorm3/trunk/libraries/Validation/.flexLibProperties
          cairngorm3/trunk/libraries/ValidationTest/.actionScriptProperties
          cairngorm3/trunk/libraries/lib-parent/pom.xml
      Removed Paths:
          cairngorm3/trunk/libraries/ContractTest/libs/
          cairngorm3/trunk/libraries/Integration/libs/
          cairngorm3/trunk/libraries/IntegrationDMS/libs/
          cairngorm3/trunk/libraries/IntegrationParsley/libs/
          cairngorm3/trunk/libraries/IntegrationTest/html-template/
          cairngorm3/trunk/libraries/IntegrationTest/libs/
          cairngorm3/trunk/libraries/Module/libs/
          cairngorm3/trunk/libraries/ModuleTest/libs/
          cairngorm3/trunk/libraries/Navigation/libs/
          cairngorm3/trunk/libraries/NavigationParsley/libs/
          cairngorm3/trunk/libraries/NavigationParsleyTest/html-template/
          cairngorm3/trunk/libraries/NavigationParsleyTest/libs/
          cairngorm3/trunk/libraries/NavigationSpringAS/libs/
          cairngorm3/trunk/libraries/NavigationSpringASTest/html-template/
          cairngorm3/trunk/libraries/NavigationSpringASTest/libs/
          cairngorm3/trunk/libraries/NavigationSwiz/libs/
          cairngorm3/trunk/libraries/NavigationSwizTest/html-template/
          cairngorm3/trunk/libraries/NavigationSwizTest/libs/
          cairngorm3/trunk/libraries/Observer/libs/
          cairngorm3/trunk/libraries/ObserverParsley/libs/
          cairngorm3/trunk/libraries/ObserverTest/html-template/history/
          cairngorm3/trunk/libraries/ObserverTest/html-template/index.template.html
          cairngorm3/trunk/libraries/ObserverTest/html-template/playerProductInstall.swf
          cairngorm3/trunk/libraries/ObserverTest/html-template/swfobject.js
          cairngorm3/trunk/libraries/ObserverTest/libs/
          cairngorm3/trunk/libraries/Persistence/libs/
          cairngorm3/trunk/libraries/PersistenceTest/libs/
          cairngorm3/trunk/libraries/Popup/libs/
          cairngorm3/trunk/libraries/PopupParsley/libs/
          cairngorm3/trunk/libraries/PopupTest/html-template/
          cairngorm3/trunk/libraries/Task/libs/
          cairngorm3/trunk/libraries/TaskTest/html-template/
          cairngorm3/trunk/libraries/TaskTest/libs/
          cairngorm3/trunk/libraries/Validation/libs/
          cairngorm3/trunk/libraries/ValidationTest/html-template/
          cairngorm3/trunk/libraries/ValidationTest/libs/
