7 Replies Latest reply on Dec 8, 2010 1:09 PM by dying veteran
    Creating Annotations
    Techi Panda Level 2
      Hi experts
      I want to change the default property of annotation before i inserting annotation
      i tried this but i am failed
      this.Annot.setProps({strokeColor:color.blue});
      I dont want to use this.addAnnot() function i want to change the default properties for all type of annotations.
      how to do this?
      thanks in advance
      regards
      a r u l
        • 1. Re: Creating Annotations
          You need to use this.getAnnots() and then loop over the array that it return
          in order to change the property of each annotation.
          • 2. Re: Creating Annotations
            RainbowChunChunChang
            Any sample code for looping over the array ?
            How to obtain the number of elements in the array ? by dot length ?
            Rainbow
            • 3. Re: Creating Annotations
              var annots = this.getAnnots();
              for (i=0; i<annots.length; i++) {
                   annots[i].setProps({strokeColor:color.blue});
              • 4. Re: Creating Annotations
                Techi Panda Level 2
                Hi try67 thanks a lot for your reply it helps
                the script works with annotations already created in the document
                my scope is creating annotations with three different colors red, blue, yellow.  I have defined meaning for colors
                1. Annotations with Yellow color is normal instruction
                2. Annotations with Blue color is medium instructin
                3. Annotations with Red is serious instruction
                While i am creating annotations every time i have to go and change the properties. So that i have designed three buttons Red, Blue and Yellow before I insert annotation I press Red button for Red annotations and Press Blue button for Blue annotations. This is what I am trying so that i am trying to change the annotation properties before inserting
                i hope i am clear little bit now
                a r u l
                • 5. Re: Creating Annotations
                  You can only do that if you insert the annotations with a script, using the
                  addAnnot command.
                  • 6. Re: Creating Annotations
                    Techi Panda Level 2
                    thank you try67 I can understand that i cant make it before inserting and finally i have changed the way and i am done here now i want to show the button always while open acrobat
                    here is my work
                    app.addToolButton({
                    cName: "Blue",
                    cExec: "Cblue();",
                    cTooltext: "My toolbar button 1",
                    nPos: 0
                    function  Cblue()
                    this.syncAnnotScan();
                    var myAnnotList = this.getAnnots({
                    nSortBy: ANSB_ModDate,
                    for (i=0; i<myAnnotList.length; i++) {
                    if([i]==0)
                         myAnnotList[i].setProps({strokeColor:color.blue});
                    regards
                    a r u l
                    • 7. Re: Creating Annotations
                      dying veteran
                      Your code is very unreadable to help due to poor indentation and no comments which you should put. Here I do cleanup for you :
                      app.addToolButton({
                            cName: "Blue",
                            cExec: "Cblue();",
                            nPos: 0
                      function  Cblue()
                        this.syncAnnotScan(); //
                          if([i]==0){
                            myAnnotList[i].setProps({strokeColor:color.blue}); //
