5 Replies Latest reply on Dec 8, 2010 3:38 AM by jfb00
    Display image
    jfb00 Level 3
      Hi all,
      how can I display an image in a datagrid column base on the value of my data?
      The value of my data column could be 0 or 1. If it is one I want to display an image, I try to use label function but I cannot display the image.
      Here is what I have:
      [Bindable]
      [Embed(source="assets/images/lock.png")]
      public var lockImage:Class;
      private function checkLocked(item:Object, dc:DataGridColumn):Image{
         if (item!=null){
            if (item.ISLOCKED == 1)
               var img:Image=new Image();
               img.source = "assets/images/lock.png";
               return img;
         return null;
      Johnny
        • 1. Re: Display image
          saisri2k2 Level 4
          you have to use customitem renderers in that case
          something similar http://www.roseindia.net/tutorial/flex/flex4/components/viewstatewithcustomitemrenderer.ht ml
          • 2. Re: Display image
            jfb00 Level 3
            Thanks for you reply and help.
            I started like that but I got stuck, now I got the solution if anyone need this later.
            Regards
            Johnny
            <mx:DataGridColumn headerText="LOCK" dataField="ISLOCKED" width="100">
                                <mx:itemRenderer>
                                    <mx:Component>
                                        <mx:VBox>
                                        <mx:Script>
                                            <![CDATA[
                                                import mx.core.BitmapAsset;
                                                [Bindable]
                                                private function checkLocked():void{
                                                    if (data.ISLOCKED == 1){
                                                        var asset:BitmapAsset = new lockImage() as BitmapAsset;
                                                        img.source = asset;
                                                    }else{
                                                        img.source = "";
                                        </mx:Script>
                                        <mx:Image id="img" creationComplete="checkLocked()" />
                                        </mx:VBox>
                                    </mx:Component>
                                </mx:itemRenderer>
                            </mx:DataGridColumn>
            • 3. Re: Display image
              jfb00 Level 3
              Forgot to close this.
              • 4. Re: Display image
                Flex harUI Adobe Employee
                Don't forget to all addChild(img)
                • 5. Re: Display image
                  jfb00 Level 3
                  Got that Alex,
                  I have an issue with this, first time the images display correctly in the corresponding row, if I move to a different screen and come back the image display in a different row that the info is not correct. What is the issue here?
                  Looks like the index counter of the rows increase every time I leave and come back to the screen.
                  Johnny
