3 Replies Latest reply on Dec 7, 2010 10:03 AM by kglad
    unique Random numbers
    tripleA999 Level 1
      How to get unique random numbers every time in AS3
      I have searched but not able to get satisfactory results
        • 1. Re: unique Random numbers
          what's wrong with Math.random()?
          the chances of getting a duplicate is pretty small.  but you could use an array to make sure if that's a concern.
          • 2. Re: unique Random numbers
            tripleA999 Level 1
            var rand :Number;
            rand = Number(movXml.movie.length());
            for(var n:uint = 0 ; n<5 ; n++)
            num1 = Number(Math.round(Math.random()* ((rand-1) - 0) + 0 ) );
            if(tempArray.indexOf(num1) == -1)
            tempArray.push(num1);
            //trace(tempArray);
            num2  = Number (tempArray[0]);
            //trace("num1:"+num2);
            trace(tempArray);
            some time this produce more than 5 numbers
            and some time less than 3
            I want 4 random numbers , but different
            the above loop runs 4 times , so if number is repeated , it will not add to Array , hence i will not able to get 4 Required numbers
            • 3. Re: unique Random numbers
              use:
              var tempArray:Array=[]
              for(var i:uint=0;i<movXml.movie.length()){
              tempArray.push(i);
              shuffle(tempArray);
              // you can now iterate through tempArray for random integers from 0 to moveXml.movie.length()-1
              function shuffle(a:Array) {
                  var p:int;
                  var t:*;
                  var ivar:int;
                  for (ivar = a.length-1; ivar>=0; ivar--) {
                      p=Math.floor((ivar+1)*Math.random());
                      t = a[ivar];
                      a[ivar] = a[p];
                      a[p] = t;
