6 Replies Latest reply on Dec 8, 2010 6:57 AM by Rob_RH
    Insert XML to BLOB
    Rob_RH Level 1
      I'm experienceing a problem using the Foundation / Execute Query component.
      I'm trying to insert XML into a table using the following INSERT Statement:
      INSERT INTO temp_registration (ID, registrationXML)
      VALUES ({$ /process_data/@lastID $}, '{$ /process_data/registrationXML $}')
      lastID (integer variable) and the registrationXML (xml variable) are populated during the process.
      The insert statement works, but the result i see in the database is not what i expect:
      The input (simplified):
      <XML>
        <Account>
          <AccountEmail>email@email.com</AccountEmail>
          <FirstName>Rob</FirstName>
        </Account>
        <Request>
          <documentID>1</documentID>
        </Request>
      </XML>
      The result in the database looks like:
          email@email.com
          Rob
          1
      When using MySQL Workbench with the following INSERT statement the data is inserted as i expect...
      INSERT INTO temp_registration (id, registrationXML)
      VALUES (55, '<?xml version="1.0" encoding="utf-8"?>  <XML>      <Account> <AccountEmail>email@email.com</AccountEmail>        <FirstName>Rob</FirstName>             </Account>                            <Request>                             <documentID>1</documentID>        </Request>       </XML>')
      The LiveCycle logs states the following btw:
      2010-12-07 15:11:44,850 INFO  [SqlHelper] execute statement: INSERT INTO temp_registration (ID, registrationXML)
      VALUES (44, '
          email@email.com
          Rob
          1
      Where and why does this interpreation of my inputXML come from??
      Thx!
        • 1. Re: Insert XML to BLOB
          Jasmin Charbonneau Level 4
          It' because of the double quotes in the XML.
          The easiest way around this is to use parameterized query.
          Your SQL statement will become
          VALUES (?, ?);
          and then you can associate the variable in the table and the right data type.
          Jasmin
          • 2. Re: Insert XML to BLOB
            Rob_RH Level 1
            Thanks Jasmin for your quick response.
            I Changed the insert query to:
            Variables defined are INT and XML (w3c.org.dom.document).
            Datatype in registrationXML column in DB is BLOB.
            The result is this error in the workbench:
            2010-12-08 08:51:44,852 INFO  [PreparedSqlHelper] execute statement: INSERT INTO temp_registration (ID, registrationXML)
            VALUES (61,?)
            2010-12-08 08:51:48,718 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.idp.dsc.jdbc.exception.JDBCIllegalParameterException message:Type mismatch is found when preparing SQL statement. Expecting type 'blob', but got type 'DocumentImpl' while invoking service JdbcService
            • 3. Re: Insert XML to BLOB
              Are you sure your registrationXML is of type w3c.org.dom.document?
              The error says you're providing DocumentImpl which is an Adobe document.
              Just XML as your data type in Workbench,.
              Jasmin
              • 4. Re: Insert XML to BLOB
                Rob_RH Level 1
                I'm sure. To be sure i deleted the variable and created it again:
                • 5. Re: Insert XML to BLOB
                  I've always use com.adobe.idp.Document in the Blob.
                  Could you use that data tye instead?
                  Jasmin
                  • 6. Re: Insert XML to BLOB
                    Rob_RH Level 1
                    This works indeed, thanks to your instructions!
                    The XML is propery inserted to the database. When the XML contains no characters like & the XML can be pulled from the database and inserted to a w3c.org.dom.document (XML variable).
                    When & is used somewhere in the XML i receive the following error:
                    ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
                        at com.adobe.idp.dsc.util.CoercionUtil.toDOMDocument(CoercionUtil.java:688)
                        at com.adobe.idp.dsc.util.CoercionUtil.toDOMDocument(CoercionUtil.java:693)
                        at com.adobe.idp.dsc.util.CoercionUtil.toType(CoercionUtil.java:998)
                        at com.adobe.idp.dsc.util.CoercionUtil.toType(CoercionUtil.java:841)
                        at com.adobe.workflow.datatype.runtime.support.AbstractDataTypeRuntimeHandler.coerceFrom(Abs tractDataTypeRuntimeHandler.java:64)
                        at com.adobe.workflow.datatype.runtime.impl.xml.XMLRuntimeHandler.coerceFrom(XMLRuntimeHandl er.java:207)
                        at com.adobe.workflow.datatype.runtime.impl.xml.XMLRuntimeHandler.getNode(XMLRuntimeHandler. java:112)
                        at com.adobe.workflow.dom.VariableElement.setBoundValue(VariableElement.java:97)
                        at com.adobe.workflow.pat.service.PATExecutionContextImpl.setProcessDataValue(PATExecutionCo ntextImpl.java:831)
                        at com.adobe.idp.dsc.jdbc.JDBCService.querySingle(JDBCService.java:268)
                        at sun.reflect.GeneratedMethodAccessor1367.invoke(Unknown Source)
                        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                        at java.lang.reflect.Method.invoke(Unknown Source)
                        at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                        at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                        at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                        at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
                        at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                        at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
                        at sun.reflect.GeneratedMethodAccessor691.invoke(Unknown Source)
                        at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
                        at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
                        at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
                        at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
                        at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
                        at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
                        at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
                        at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
                        at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
                        at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
                        at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
                        at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
                        at org.jboss.ejb.Container.invoke(Container.java:960)
                        at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
                        at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
                        at $Proxy342.doBMT(Unknown Source)
                        at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
                        at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
                        at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
                        at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                        at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
                        at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                        at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
                        at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
                        at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
                        at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:20 9)
                        at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
                        at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                        at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:886)
                        at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:510 )
                        at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:888)
                        at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2792)
                        at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMT Bean.java:697)
                        at sun.reflect.GeneratedMethodAccessor1349.invoke(Unknown Source)
                        at $Proxy371.asyncInvokeProcessCommand(Unknown Source)
                        at com.adobe.idp.workflow.dsc.service.ProcessCommandExecutorService.invokeProcess(ProcessCom mandExecutorService.java:55)
                        at sun.reflect.GeneratedMethodAccessor1353.invoke(Unknown Source)
                        at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:154)
                        at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
                        at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:227)
                        at sun.reflect.GeneratedMethodAccessor681.invoke(Unknown Source)
                        at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
                        at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
                        at $Proxy341.doSupports(Unknown Source)
                        at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
                        at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:165)
                        at com.adobe.workflow.engine.PEInvokeProcessCommand.execute(PEInvokeProcessCommand.java:126)
                        at com.adobe.workflow.workadapter.WorkflowCommandExecutionUnit.execute(WorkflowCommandExecut ionUnit.java:22)
                        at com.adobe.idp.dsc.workmanager.adapter.ManagedAsynchronousWorkAdapter.run(ManagedAsynchron ousWorkAdapter.java:70)
                        at org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java:204)
                        at org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrapper.java:275)
                        at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:743)
                        at java.lang.Thread.run(Unknown Source)
                    Caused by: ALC-DSC-119-000: com.adobe.idp.dsc.util.InvalidCoercionException: Cannot coerce object: [B@4da6c2f6 of type: [B to type: interface org.w3c.dom.Document
                        at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
                        at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
                        at com.adobe.idp.dsc.util.DOMUtil.parseDocumentFromString(DOMUtil.java:185)
                        at com.adobe.idp.dsc.util.DOMUtil.parseDocumentFromString(DOMUtil.java:130)
                        at com.adobe.idp.dsc.util.DOMUtil.parseDocumentFromStream(DOMUtil.java:258)
                        at com.adobe.idp.dsc.util.CoercionUtil.toDOMDocument(CoercionUtil.java:675)
                        ... 135 more
