4 Replies Latest reply on Jun 18, 2011 8:35 AM by perpor2
    AIR Timer()
    daslicht Level 2
      Hello,
      how can I make a Timer working in an AIR Application ?
      When I try to create a timer like var t:Timer = new Timer(1000) it sais that Timer do not expect more than 0 arguments ??
      I even tried created a external Class file but as far as I create an instance of it I get an error ... ??
        • 1. Re: AIR Timer()
          daslicht Level 2
          SOLVED
          • 2. Re: AIR Timer()
            perpor2 Level 1
            how have you soldved ??? I have the same problem, thanks,,,,
            • 3. Re: AIR Timer()
              daslicht Level 2
              <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                          xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="windowedapplication1_creationCompleteHandler(event)">
                   <fx:Script>
                        <![CDATA[
                             import flash.utils.Timer;
                             import mx.events.FlexEvent;
                             [Bindable]
                             private var t:flash.utils.Timer = new flash.utils.Timer(1000);
                             protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                                  t.addEventListener(TimerEvent.TIMER, timer_handler);
                                  t.start();
                             private function timer_handler( e:TimerEvent):void
                                  trace(t.currentCount);
                   </fx:Script>
              </s:WindowedApplication>
              Importing import flash.utils.Timer; alone down not work !
              I dont know why it is not working, probably someone like to enlighten us.
              Funny thing is that in another project of mine its working instanttly without forcing the package like : t:flash.utils.Timer
              • 4. Re: AIR Timer()
                perpor2 Level 1
                thanks ! for my need I have also solved using the class getTimer(),
                (really I was using the class Date(), but I was not able to set this class with the milliseconds...)
