4 Replies Latest reply on Dec 8, 2010 3:33 PM by DarrenBiz
    Reading text files
    phil25840
      I am having trouble figuring out something that is very common in other languages: how to read a local text file. Can somebody enlighten me on how to do this in Flex 4? Thanks!
        • 1. Re: Reading text files
          DarrenBiz Level 3
          There are a number of ways to achieve this. Can you be more specific as to what you mean by "local"
          Is the file local to the file system that the SWF is running (i.e. on the server)  or is the file a local file on the end-user's machine that they have to select with a File Browser?
          • 2. Re: Reading text files
            phil25840 Level 1
            By "local file system" I am referring to a text file that resides in the same directory on the server as the swf. I simply want to apply some configuraiton settings to my application. Thanks...
            • 3. Re: Reading text files
              DarrenBiz Level 3
              One way to do it would be to use the URLLoader class:
              http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/net/URLLoader.htm l
              http://actionscriptexamples.com/2008/02/27/loading-url-encoded-variables-into-a-flash-appl ication-using-the-urlloader-class-in-actionscript-30/
              //params.txt is a local file that includes: firstName=Tom&lastName=Jones
              var lbl:TextField = new TextField();
              var urlRequest:URLRequest = new URLRequest("params.txt");
              var urlLoader:URLLoader = new URLLoader();
              urlLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
              urlLoader.addEventListener(Event.COMPLETE, urlLoader_complete);
              urlLoader.load(urlRequest);
              function urlLoader_complete(evt:Event):void {
                  lbl.text = urlLoader.data.lastName + "," + urlLoader.data.firstName;
                  addChild(lbl);
              • 4. Re: Reading text files
                DarrenBiz Level 3
                Or my personal favourite is to create a proper class and event to handle the loading of XML content...
                [XMLContentLoader.as]
                package
                     import flash.events.Event;
                     import flash.events.HTTPStatusEvent;
                     import flash.events.IOErrorEvent;
                     import flash.events.SecurityErrorEvent;
                     import flash.net.URLLoader;
                     import flash.net.URLLoaderDataFormat;
                     import flash.net.URLRequest;
                     import flash.net.URLRequestMethod;
                     import flash.xml.XMLDocument;
                     import mx.controls.Alert;
                     import mx.rpc.xml.SimpleXMLDecoder;
                     [Event(name="loadContent", type="XMLContentLoaderEvent")]
                     [Event(name="contentLoaded", type="XMLContentLoaderEvent")]
                     [Event(name="loadContentError", type="XMLContentLoaderEvent")]
                      * An XML Content Loader, that can load xml file and parse it to an
                         * Object which will be dispatched with the Content Loaded event.
                     public class XMLContentLoader extends URLLoader
                           * XML file url
                          public var url:String="";
                           * XML Content Loader state variable
                          public var state:int;
                           * @Constructor
                          public function XMLContentLoader()
                               this.dataFormat = URLLoaderDataFormat.TEXT;
                               super();
                           * Start to load content
                          public function sendRequest():void
                               try
                                    var _request:URLRequest = new URLRequest();
                                    _request.url = this.url;
                                    _request.method = URLRequestMethod.GET;
                                    this.addEventListener(Event.COMPLETE, onResultHandler);
                                    this.addEventListener(HTTPStatusEvent.HTTP_STATUS, httpStatusHandler);
                                    this.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
                                    this.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                                    this.load(_request);
                                    var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.LOAD_CONTENT);
                                    dispatchEvent(ev);
                               catch(e:Error)
                                    trace("Unable to load URL: "+this.url);
                                    Alert.show("Unable to load URL: "+this.url, "XML Load Error");
                           * On content loaded handler.
                          private function onResultHandler(event:Event):void
                                var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.CONTENT_LOADED);
                               ev.data = convertXMLtoArrayCollection(new XMLDocument(event.target.data));
                               ev.rawEvent = event;
                               dispatchEvent(ev);
                          private function httpStatusHandler (e:HTTPStatusEvent):void
                               this.state = e.status;
                          private function securityErrorHandler (e:SecurityErrorEvent):void
                               trace("securityErrorHandler:" + e);
                               Alert.show("securityErrorHandler:" + e, "XML Load Error");
                          private function ioErrorHandler(e:IOErrorEvent):void
                               var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.LOAD_CONTENT_ERROR);
                               ev.rawEvent = e;
                               dispatchEvent(ev);
                               trace("ioErrorHandler: " + e);
                               Alert.show("ioErrorHandler: " + e, "XML Load Error");
                          private function convertXMLtoArrayCollection(xmlDoc:XMLDocument):Object
                               var decoder:SimpleXMLDecoder = new SimpleXMLDecoder;
                               var data:Object = decoder.decodeXML(xmlDoc);
                               return data;
                [XMLContentLoaderEvent.as]
                package
                     public class XMLContentLoaderEvent extends Event
                           * The xml file content will be converted and stored into this object.
                          public var data:Object;
                           * All original event info is saved in this variable.
                          public var rawEvent:Event;
                           * @default
                          public static const LOAD_CONTENT:String = "loadContent";
                           * @default
                          public static const CONTENT_LOADED:String = "contentLoaded";
                           * @default
                          public static const LOAD_CONTENT_ERROR:String = "loadContentError";
                           * @param type
                           * @param bubbles
                           * @param cancelable
                          public function XMLContentLoaderEvent(type:String, bubbles:Boolean=false, cancelable:Boolean=false)
                               super(type, bubbles, cancelable);
                           *  @private
                          override public function clone():Event
                               var event:XMLContentLoaderEvent = new XMLContentLoaderEvent(type, bubbles, cancelable);
                               event.data = data;
                               event.rawEvent = rawEvent;
                               return event;
