3 Replies Latest reply on Dec 8, 2010 2:35 AM by SimonLinden
    Find string with varying numbers
    SimonLinden
      I have a long unformatted text which regularly has references which should be in italic. These references look like this:
      Lag (int:int)
      where int represents an integer. (eg. Lag (2009:74) or Lag (2010:347)).
      I would like a script which finds all of these strings and applies a character style to it.
      I have no experience of ID-scripting but I know actionscript so if somebody has a script which does something similar to this I could probably tweak it to fit my needs.
        • 1. Re: Find string with varying numbers
          Kasyan Servetsky Level 5
          I think you can achieve this without script.
          In Find/Change GREP use the following settings:
          Find what: Lag\s\(\d+:\d+\)
          Change to: leave empty
          Change format: Font style > Italic
          Kasyan
          P.S. I am not an expert in GREP, may be someone knows a better solution
          • 2. Re: Find string with varying numbers
            Your GREP is fine, except it only looks for the name "Lag"! Slightly better:
            \b\w+\s\(\d+:\d+\)
            which picks up any first word right before the reference. Even better still:
            \b\w[\w\-]+\s\(\d{4}:\d+\)
            so it will pick up "Gell-Mann (1964:155)". And yet even better (but at this point it's going to depend on what your references actually look like):
            \b\w[\w\-]+\s\(\d{4}:\d+(-\d+)?\)
            so it will pick up "Gell-Mann (1964:155-156)" as well. But at some point things gets too complicated to automatically replace. This GREP will not match "Watson & Crick (1953)", for example. (On seeing this, it's actually simple to add this particular variant to the GREP string; I meant to point out there are lots of different ways write any reference.)
            It's also a far better idea not to simply change to Font style > Italic, but to a character style instead (as the OP notes).
            • 3. Re: Find string with varying numbers
              SimonLinden Level 1
              Thanks alot!
              Didn't know about GREP. Will be a great help.
