3 Replies Latest reply on Dec 8, 2010 6:51 AM by the_wine_snob
    Version help
    Prozz
      hey guys many of you may remember me from the premier pro forum, as i can't afford to buy a new laptop a friend of mine recomended elements instead of pro as its a more home editing friendly software.
      i was wondering what the best version to get was for the laptop im using.
      http://www.currys.co.uk/gbuk/advent-modena-m200-06605480-pdt.html?srcid=867&xtor=AL-89&ist CompanyId=bec25c7e-cbcd-460d-81d5-a25372d2e3d7&istItemId=mrqqmra&istBid=t
      there is the laptop that i am using again.
      ive downloaded the trial for premiere elements 9, slow as it may be it works not too bad really. but i need more information as i have heard that previous versions are better.
      i found out the issue why my laptop wouldnt play HD video even on playback aswel as mentioned in the previous forums, there was a dodgy bit of RAM in there as it kept blue screenign everytime i turned it on. its been replaced now.
      if you guys can help that would be perfect
      thanks
        • 1. Re: Version help
          nealeh Level 5
          Describing something as 'better' is very much a subjective point of view - there can be no simple answer. If you've been browsing this PRE forum you can see that what one has problems with, another may not. For example I run PRE7 perfectly with W7 64-bit, others cannot. I also run PRE9 on the same system (multiple versions can co-exist). To me PRE9 is slower opening files and scrolling through the timeline, others find it fine.
          To answer your question (from my perspective)
          • Don't get PRE8 - it is almost universally condemned.
          • Choosing between PRE7 and PRE9 is a tough call (performance issues being my reason for having both versions).
          • PRE7 seems the more stable product, with fewer crashes and good performance.
          • PRE9 adds some features (but removed others) and provides much better device support (many DSLRs and Flip for example). Although more robust than PRE8 it runs slower than PRE7 for me.
          You commented that the PRE9 trial performs slow but adequately for you. If that is something you can live with, stay with it. If you can't live with it then go for PRE7.
          If you have some spare cash I would invest it in more memory and a second drive. 2GB RAM, a Celeron processor, and a single hard disk are pretty much borderline for running PRE at all. AVCHD will be a struggle.
          Cheers,
          Neale
          • 2. Re: Version help
            Prozz Level 1
            thank you i was tempted with 7 as it is cheaper and has better reviews.
            and as for the memory upgrade, i may look into that with any christmas moneys
            thank you
            • 3. Re: Version help
              the_wine_snob Level 9
              In general, PrE 7 seemed to be a very solid version. PrE 8 - not nearly so much. With PrE 9, many feel that they have PrE 7 on steroids, but as Neale points out, YMMV.
              So very much depends on:
              Computer
              Configuration
              Assets (where the source footage came from)
              There are several reports, like Neale's, where it seems that PrE 9 requires more resources, and also might just be slower, than its predecessor. Some feel the same way about PrPro CS5 vs CS4, but so much depends on the above variables.
              If you do go with PrE, over an older PrPro, I strongly suggest that you pick up a copy of Steve Grisetti's book for that version. It will help you locate where things are now located, and what they are called in PrE. Several critical differences. Also, you will have a new interface to learn. Though PrE 4 is a tad closer to PrPro 2.0, I still have to "hunt and peck," when using it, 'cause I have a PrPro interface mindset.
