2 Replies Latest reply on Dec 8, 2010 8:10 AM by spiritonline123
    Auto play embedded swf only works locally
    spiritonline123
      Hi all,
      I'm having a problem I hope you can help me with.
      This is the scenario:
      I've made a simple "mini site" in flash catalyst where pretty much each page has a swf emdedded that I created in flash professional CS5. I've embeded them trough the file>import>swf. I then set an action: play swf for all the required states. Now when I run the project on ctrl + enter the swf files will automaticly play when you open the page, which is how I want it. However, when I publish the project and view it online this is not the case. The swf files will only start playing after you've visited them twice.
      Usefull links:
      http://media-surfer.nl/you/portfolio.html > Click the green flashing button to open the "mini site" created in flash catalyst.
      http://media-surfer.nl/you/flash/Main.html > Try the html file that catalyst generated.
      http://media-surfer.nl/you/flash/Main.swf > Try the swf that catalyst generated.
      http://www.mediafire.com/?2at1pfz9p9dz3cd > download my FXP file to check for yourself.
      I really hope someone can help me out on this one! Thanks a ton in advance
