31 Replies Latest reply on Feb 9, 2013 6:20 PM by tyjones2013
    Templates missing since update > 5.0.3
    humandesigner
      Hey community
      I have following problem.
      Since I updated my Premiere Pro CS5 to version 5.0.3 this morning I am not able to open the projects I have been working on yesterday.
      It seems the update deleted codecs and templates I used in this projects sequences as I am told they are missing when I try to open the projects.
      And when I want to create a new project I suddenly have a only a few templates to choose from.
      As if this was a demo.
      This version is activated and had all templates and codecs installed yesterday.
      Does anybody have an idea how to get them back oder to undo the update.
      Best greetings from Germany
      humandesigner
        • 1. Re: Templates missing since update > 5.0.3
          Colin Brougham Level 6
          ...and the "Hey I'm a Premiere Pro Update and all your retail installation are belong to us" reversion to trial mode rears its ugly head yet again...
          This has been a recurring nightmare with Premiere Pro updates, unfortunately. For a number of users, installing an update somehow causes the software to revert to trial mode, which prevents you from using a number of formats and codecs that you previously had access to (like MPEG). Sadly, the only remedy is to deactivate your software, uninstall it, run the Adobe CS5 Clean Tool a couple of times (rebooting each time), and then reinstall. Immediately after reinstallation, launch something like Bridge and perform the updates from there.
          Wish there was an easier way, but this has been a random issue since sometime in the CS4 cycle. Post back if you get into any trouble during the process; as long as you proceed as listed above, you should be back up and running.
          • 2. Re: Templates missing since update > 5.0.3
            humandesigner Level 1
            Wew, that's sad news.
            But thank you for the quick response.
            I will try to find an easier way but at least I know what to do if this does not work.
            Thank you, Colin.
            Greetings
            Guido
            • 3. Re: Templates missing since update > 5.0.3
              davidbeisner2010 Level 3
              FWIW, this doesn't appear to be universal with this update... mine went smoothly.
              • 4. Re: Templates missing since update > 5.0.3
                Do let us know if you discover one--so far, anyone else that has been struck by this issue (with previous updates) has had to go through this deactive/uninstall/clean/reinstall/update routine. It's not pretty, I'll grant you, but it seems to be the only way to get back up and running.
                Sorry for the bad news... good luck
                • 5. Re: Templates missing since update > 5.0.3
                  I didn't say it was, and it hasn't affected everyone with previous updates, either. As far as I can tell, no one has ever uncovered the series of factors that contribute to this. Personally, every single CS4 update forced me to do this dance, on both of my systems; I haven't had a problem with any of the Premiere Pro CS5 updates, but I can't install the current Photoshop or Illustrator updates (both fail on both systems). There seems to be little rhyme or reason for it...
                  • 6. Re: Templates missing since update > 5.0.3
                    Strange... I didn't stop to see what the updates were, but mine just cleanly updated PS and AI along with the PR.
                    • 7. Re: Templates missing since update > 5.0.3
                      It might have something to do with rights during the update process.
                      Premiere had another problem to playback media inside accounts that had no admin rights (the usual kind in a company environment).
                      This could be solved by opening Premiere once in an account with admin rights and it worked in the other one again.
                      I asked the hotline and I am waiting for an answer now.
                      I let you know about the results.
                      All the best
                      • 8. Re: Templates missing since update > 5.0.3
                        Todd_Kopriva Level 8
                        Keep us posted. The advice given to you so far is the same advice that I'd give. We've got some folks looking into this issue, and any additional information that you give on this thread would be helpful.
                        • 9. Re: Templates missing since update > 5.0.3
                          Rights has been a problem starting with Vista and continuing on to Win7
                          Not really Adobe's fault/problem (I think) but more with the way Microsoft has made things "more secure" that is causing problems
                          Over in the Encore side of things, I found out that even though I am the ONLY user of my computer, so I installed and run everying as a single Administrator account, I had a problem the first time I tried to create a dual layer DVD (actually, an ISO to burn later with Imgburn)
                          After reading in that forum, I found out that the solution (work around) was to right click the Encore icon and select Run as Administrator... this would allow my dual layer ISO to be created
                          The extra right click step is NOT required to create a single layer ISO
                          Most odd
                          • 10. Re: Templates missing since update > 5.0.3
                            calebbaker Level 1
                            The same thing happened to me this update............ This sucks.. Time I don't have...
                            • 11. Re: Templates missing since update > 5.0.3
                              dwh131
                              Add me to the list that has this problem after updating to 5.0.3 (Mac 10.6.4) . I don't have the time to jump through all these hoops so I used Time Machine to revert Premiere Pro to 5.0.2. Seems to be working fine now, but I am not sure what to do about the update. I don't have the time to waste reinstalling everything, I just want it to work!
                              • 12. Re: Templates missing since update > 5.0.3
                                Unfortunately, there's a problem such that---in a small number of cases---uninstalling and reinstalling is the only way to make the full program work after an update. It doesn't take that long. I had to do it on one of my computers, and it took less than half an hour. Better to spend this half and hour and get a lot of bug fixes than to avoid the update. You run the risk of losing a lot more time down the road if you're bitten by one of the bugs because you don't take the update.
                                • 13. Re: Templates missing since update > 5.0.3
                                  DTEurope_1000
                                  I´m back to normal....
                                  What I did:
                                  I deinstalled Production Premium completly -> Reboot -> run Adobe Cleaner Tool (found nothing to deinstall) -> new Installation from DVD -> run Adobe update -> everthing ok
                                  Here the amount of work:
                                  Deinstall: 5-10 minutes
                                  Reboot: some seconds
                                  Adobe Cleaner: some seconds
                                  new Install: less than 1 hour
                                  update: 1 hour
                                  TOTAL: 1-2 hours
                                  Used Enviroment:
                                  Mac Book Pro i7
                                  Production Premium upsell Package
                                  I previous installed the Adobe Trial version and entered my shipped serial number to transfer the trial software to a "real" software. I guess that this caused the Problems with Premiere Pro which went back to a trial version after the update.
                                  Now, I used the shipped DVD as basis and hope that problems which I had  will never pop up again.
                                  Many thanks to all of you which helped me here.
                                  BR Ralf
                                  • 14. Re: Templates missing since update > 5.0.3
                                    Thanks for the update, Ralf. I'm glad that the fix was relatively painless.
                                    • 15. Re: Templates missing since update > 5.0.3
                                      DTEurope_1000 Level 1
                                      I´m also ver happy about that.
                                      But the deactivation did not work proper (doesn´t matter to me). The Tool shows "deactivation successful". After the App restart: App still activated. The second option (deactivation with remove of serial number) works. Maybe it is only recorded to the Adobe Server....many activations and deactivations from my machine.
                                      • 16. Re: Templates missing since update > 5.0.3
                                        trentinams
                                        I am now at a lot of hours trying to get this working. The upgrade to 5.0.3 made ppcs5 stop working. Could not open projects from the day before. When I created a new project, HDV was gone from capture format, avchd presets were gone, and mts files could no longer be edited. Did a full uninstall (several times), used the clean utility (many times), rebooted (way too often). Full reinstall. Now I have HDV capture format, but avchd presets still gone. MTS files though can be edited. So I have the MPEG features, except for the presets. What can I do to get this working??
                                        I even tried restoring with Tim Machine, but I get the same thing: HDV capture, but no presets. Is there some other file that defines these presets? I can then restore that file and be back up and running.
                                        This is runniong on 2009 MacBook Pro. OSX 10.6.5
                                        • 17. Re: Templates missing since update > 5.0.3
                                          jabloomf1230 Level 1
                                          This is the first problem that I've had with CS5. Deactivated, uninstalled, rebooted, used CS5 Clean tool and rebooted a few times. Then tried to install and got this:
                                          Exit Code: 7
                                          -------------------------------------- Summary --------------------------------------
                                          - 0 fatal error(s), 68 error(s), 68 warning(s)
                                          WARNING: OS requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                                          WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                                          Then a bunch of  installations failed because of  dependent failures etc.
                                          No A/V or anything else out of the ordinary running on Win 7 x64 Ultimate. Whatever 5.03 does, it creates havoc. It is no longer possible to install CS5. I remember seeing some older threads about this problem, but now I can't find them.
                                          EDIT: NM, I found the "good old code 1402 thread", which explains how to change the registry key permissions for the Visual C libraries. Two hours later and everything is back in business. Dare I update to 5.03 again?
                                          • 18. Re: Templates missing since update > 5.0.3
                                            Sooooo.
                                            After installing the update on my other MacPro (with an Admin account) without any trouble, I decided to follow Colins path.
                                            Thanks again, Colin.
                                            This was successful but took me 3 hours of my workingtime.
                                            I hope Adobe will work on this issue for the future. As working on an account with restrictions is the usual and safer way in a company.
                                            And if it is technically problematic, just inform the users to install as admin to avoid problems.
                                            All the best
                                            Guido
                                            • 19. Re: Templates missing since update > 5.0.3
                                              borys_k Level 1
                                              I have just uninstalled and installed premiere pro from entire master collection CS5 and everything came back ok ;]
                                              • 20. Re: Templates missing since update > 5.0.3
                                                the_wine_snob Level 9
                                                The Revert to Trial Bug strikes without warning, and only for some. Why? Not even sure if Todd knows. It's been happening since about the first update for CS4. I have no way to collect figures on the ratio of successful updates vs the Revert updates, but I'd say that it's pretty small. Still, when it hits, it is no "small" matter. Hope that CS5.5 will never suffer from this, and that it will become a footnote in history.
                                                • 21. Re: Templates missing since update > 5.0.3
                                                  Good news! I suggest that one do the listed steps, and that then upon the reinstall, they do all updates, before ever even launching the program. Usually, the Revert to Trial Bug never strikes twice, but I suppose that it is possible.
                                                  • 22. Re: Templates missing since update > 5.0.3
                                                    borys_k Level 1
                                                    Unfortunetly I use CS5 Version - so when you hoped that it will stop it didn't, it is still a threat. It took me about half an hour to uninstall Premiere Pro and Install it again. Everything is fine for now.
                                                    • 23. Re: Templates missing since update > 5.0.3
                                                      In all of the update versions, from CS4, I cannot recall any user encountering this Bug a second time. Might have happened, and they just knew the drill, so never posted about it?
                                                      My fingers are X'ed for you, and let's hope that it never surfaces for you again. PrPro CS5.5 will be out in May, and I hope that we never see this Bug after that, though CS4 & CS5 users will still be vulnerable.
                                                      • 24. Re: Templates missing since update > 5.0.3
                                                        DWTNA
                                                        I'd greatly appreciate some guidence with the revert to trial issue.  First, do I have to remove all of the Master Suite applications to correct this problem or is it possible to remove just Premiere Pro?  Second, will the re-install process will have any impact on any work that is currently underway regardless of the application.  Specifically, I am worried about losing my DreamWeaver and Photoshop settings, add-ons, work in progess files, etc.
                                                        Thanks in advance for any help.
                                                        • 25. Re: Templates missing since update > 5.0.3
                                                          Yes, you do have to reinstall the entire suite (from my understanding). You
                                                          will probably have to redo any custom settings in your programs, and reset
                                                          any addons. You should not, however, lose any data files you're working on
                                                          in Dreamweaver, as long as they're not stored in the Dreamweaver program
                                                          files folder.
                                                          You'll have to uninstall your suite, run the registry cleaner app from Adobe
                                                          a couple times with restarts in between each, and then do your install
                                                          again.
                                                          • 26. Re: Templates missing since update > 5.0.3
                                                            borys_k Level 1
                                                            I am not sure about why are they saying this, but I uninstalled only Premiere Pro, and installed it back again. Everything was fine. I just copied my work templates and files from the working folder and it was fine! . The rest of Master Collection was safe!
                                                            take care and no problem!
                                                            • 27. Re: Templates missing since update > 5.0.3
                                                              Good news! I may have been mistaken. Glad it worked for you!
                                                              • 28. Re: Templates missing since update > 5.0.3
        calebbaker Level 1
        No you do not have to uninstall the entire suite.. When you open the uninstall program it asks you what you want to uninstall. Just check PrePro and you only have to reinstall that program
        • 29. Re: Templates missing since update > 5.0.3
        PaulMarty
        Hey everyone,
        I have been having the exact same issue and have battled it for the last two days.  HOWEVER: I have found a solution that works for me...
        What I am running:
        - Win 7 HP 64-bit
        - Premiere Pro CS5.5 (APP CS5.5)
        - One user account on Windows and I am Admin.
        My Issue:
        I had downloaded the Trial Version of APP CS5.5 from Adobe's website and liked it, so I bought a subscription license to it and put it in after Trial ended.  Everything was fine for about a week, and then one day when I went to open a project it said: "This project contained a sequence that could not be opened.  No sequence preview preset file or codec could be associated with this sequence type."  <- Basically it can't find codecs because they're locked back into Trial mode, and therefore cannot be touched by APP.
        What I did:
        Uninstalled APP CS5.5.
        Restarted PC
        Started the AdobeCreativeSuiteCleanerTool in Admin mode.
        Restarted PC
        Used the AdobeCreativeSuiteCleanerTool again in Admin mode. <- It couldn't find any evidence of Adobe products.
        Downloaded fresh non-trial version of APP from Adobe's website
        Restarted PC. <- just for the heck of it.
        Installed the non-trial version of APP CS5.5 on my PC and entered product key during process (as it was required)
        Restarted PC.
        Updated my Adobe products via Bridge.
        Restarted PC.
        Opened APP CS5.5 in Admin mode and still had issue, so I decided to start a new project (cause it still let me do that)
        Didn't choose any settings for project, just closed dialog.
        Went over to Help menu in upper left hand area and clicked Deactivate...
        Completely deactivated products by doing the Permanant option.
        Closed APP.
        Restarted PC.
        Opened APP CS5.5 in Admin mode, said it would start 30 day Trial.  Chose the button that let me enter product key and entered it.
        Closed APP CS5.5 and restarted it, and..........
        IT WORKED!!!!!!!!!!!!!!!!!!!!!!!
        I was able to open my project - finally!
        Anyhow, hope this woks for everyone else.  Don't know if this will work on OS X, never had the problem on it.
        This might be a combination of bugs in the activation process plus permissions in Windows, but this worked for me.
        • 30. Re: Templates missing since update > 5.0.3
        slshippee Level 1
        A much easeir workaround [using Adobe Premier Version 5.0.3 (005(MC:218798))]
        in Adobe's CS-5 Master Collection 64 bit edition of Premier for me was a result of having installed the trial version 1st, which installs without the codecs.
        A quick and easy workaround is to CREATE a brand new project after converting the trial version of PREMIER to a paid, registered version - then the new project will auto install the correct codecs and you are good to go after that.
        Steven Shippee
        Olympia, Washington
        • 31. Re: Templates missing since update > 5.0.3
        tyjones2013
        I am having the same issue with my CS6, however I also have a lot of plug-ins and preset from various websites on it. If I uninstall the program and go through the reinstall process will I loose all of my plug-ins and presets??????
