6 Replies Latest reply on Dec 8, 2010 11:18 AM by darth pathos
    Display / Hide Text Field based on drop box
    darth pathos Level 1
      Hi all,
      First time post here - wahoo!  :-)  Brand new user to LiveCycle, and so far I'm loving it - very cool application!  I'm a little stumped though and hoping someone can help....
      I'm using LiveCycle version 8.05, and trying to build a form that has a drop box with departments in our organisation.  If the user selects Items 1 - 5 on my list, I want two other fields to be autopopulated (one for Admin Assitant and one for Dept Head).  If however the user selects "Other", I want a text box to appear (it'll be hidden the rest of the time) where the person will be able to type in the department that they work for.  Right now I'm only focussing on getting the "Other" box to appear; I'll worry about the other stuff later.
      Elsewhere in my form, I have a functioning drop box that displays a Text Field depending on the selection; however, for some reason this logic isn't working with the above situation.
      My code for the working text field is (in JavaScript)
      var
      (sNewSel)
      case "1":
      switch
           TextField6.rawValue = "My text is in here";
      break;
      case "2":
      = "My second text is in here ";
      break;
      "3":
      case
      = "My third text is in here.";
      break;
      TextField6.rawValue
      default:
      break;
      TextField6.rawValue
      sNewSel = this.boundItem(xfa.event.newText);
      After many fruitless hours yesterday, I only got as far as the code below; this was more or less copied right out of a post here.  When I click the drop box selecting "Other", the Text Field doesn't display.  I have tried setting the text field to both "Hidden" and "Visible" through the object's properties, but no luck.  I've tried using IF Statements, Subforms, and anything else I could think of but am getting nowhere.
      var nSubLength = Subform1.nodes.length;
      var
      sSelectField
      for
      {if
      {switch (xfa.event.newText)
      (case "6":
      Subform1.nodes.item(nCount).presence
      break
      default:
      break
      = "invisible";;= "visible";((Subform1.nodes.item(nCount).className ==
      "field") &(Subform1.nodes.item(nCount).name== sSelectField))
      (var nCount = 0;
      nCount < nSubLength;
      nCount++) sSelectField = fieldList.rawValue;
      = sSelectField.replace(' ', '');
      Any ideas?  This is all very new to me, but I'm familiar with other programming languages, and something this simple shouldn't be this difficult, which leads me to think I'm missing something.
      Thanks in advance
      Chris
        • 1. Re: Display / Hide Text Field based on drop box
          pguerett Level 6
          It was easier to create a sample for you ...please see the attached file.  I think this is what you want.
          The code is on the change event of the DDList
          Paul
          • 2. Re: Display / Hide Text Field based on drop box
            Hi Paul - thank you thank you thank you!!!!!!!  That's exactly what I was trying to accomplish.  You've saved me from wasting time and my sanity!  (well, maybe not my sanity - that's been gone for a while :-))
            Have a great day
            Chris
            • 3. Re: Display / Hide Text Field based on drop box
              ....insert sheepish expression here...
              Hi Paul (or anyone else)
              The form you uploaded works perfectly; however, when I try the same thing on my form, the hidden text box still does not display.  I've read through more posts and have ensured everything is the same; I changed my Form properties from Adobe 7 Static to Dynamic, changed my field type to XHTML, and still nothing.  The only other thing I've noticed that's different is your form is version 9, whereas mine is 8.  If that is causing my problem, how do I go about fixing this?  If it's not, do you have any other suggestions?  I even copied your code from the Change event directly to my form, changed the names to match your code, and still nothing.  I know the code works though because the other options autopopulate the form accordingly, and
              case ("Other"):
              AdminAsst.rawValue
              = "ffff";
              DeptHead.rawValue
              Department.presence
              = "visible"
              break;
              Puts the ffff into the AdminAsst field.  In your code, there's no ";" after the "visible" but I've tried it both with and without, no such luck.
              Any ideas?  Once again your time is appreciated...........
              Chris
              • 4. Re: Display / Hide Text Field based on drop box
                pguerett Level 6
                Are the fields getting populated if I choose a 1-5 value? In Designer cright click on the Preview tab and ensure that the Dynamic option is on. This display indicates which format your file has been saved as. If it is static do a saveAs and make it dynamic.
                If that is not the issue ...then can you send me your form and I will have a look. Send it to LiveCycle8@gmail.com
                Paul
                • 5. Re: Display / Hide Text Field based on drop box
                  *mutters under breath*
                  Yup, that was the problem.  So what's the difference between going under File -> Form Properties -> Defaults and setting it there versus going to Save As?  I had set the Form Properties as Adobe 7 Dynamic, but that obviously didn't fix the issue.
                  Again - thank you thank you thank you!!!
                  Chris
                  • 6. Re: Display / Hide Text Field based on drop box
                    pguerett Level 6
                    When you save the file from Designer a processing instruction is written into the file. This instruction overrides all others. That is why the one in the Form Properties is being ignored.
                    Paul
