2 Replies Latest reply on Dec 8, 2010 10:37 AM by Jeff Bellune
    No Audio on Export
    bicjohnson
      Seasons greetings to you.
      <<insert token tale of woe about how frustrated I am and how much time i have wasted>>
      I have imported wav files that play just fine in the project panel and the source panel.  However, there is no sound when played in the project panel, the audio mixer, or when the project is exported/rendered.  The audio master meter registers no sound either.  The track is not muted and the volume levels are fine.  I have tested the same wav files on other projects and everything works the way it should.  Ideas?  I'm sure it is something simple I am forgetting.
      Thanks for your time.
